I’m trying to run a qrexec-client-vm command in a qube just before it shuts down.
I’ve created a systemd service and the script it runs; I’m confident they are running (largely because I put “sleep” calls in it, but also I have it write to a log file).
But there’s no sign that the qrexec-client-vm call in the script is happening. I do have the service file name qubes-core-agent.service as a “wanted by” in the [install] section. (This is softlinked to qubes-qrexec-agent.service, and I tried explicitly having this be a “wantedby” as well.)
Is there something more I need to do here?
[Unit]
Description=Before Shutdown
RequiresMountsFor=/home /usr/local
[Service]
Type=oneshot
RemainAfterExit=true
ExecStart=/bin/true
ExecStop=/usr/local/bin/vera-agent-cleanup
TimeoutSec=infinity
[Install]
WantedBy=multi-user.target qubes-core-agent.service
/usr/local/bin/vera-agent-cleanup contains the qrexec call. Everything else in that file executes. vera-agent-cleanup works when called directly from the command line.
I’m wondering if somehow qrexec is being disabled before this runs, in spite of my WantedBy
