I have a VM which is being slowed down noticeably (i.e. using Firefox), and this process is constantly taking up 5-10% CPU:
qrexec-client-vm sys-usb qubes.USB+3-2.1 /usr/lib/qubes/usb-import /var/run/qubes/usb-import-sys-usb-3-2.1.state
Is this supposed to be constantly running? For reference, I have a USB-Ethernet adapter and USB hardware token attached to this VM, both through the same USB hub. All USB type A and >=3.0. There’s also a USB mouse attached to the hub, and there’s a USB keyboard plugged into the computer directly.
EDIT: I have memory balancing disabled for this VM and allocated 4 CPU threads.
