qubist
December 27, 2025, 8:35am
1
The man page of qvm-prefs says:
This list is non-exhaustive. For authoritative listing, see
--help-properties and documentation of the source code.
Neither --help-properties, nor the dev doc explain the purpose and possible usage of visible_* network properties.
Where can I find info about that?
barto
December 27, 2025, 8:43am
2
Strange coincidence⦠I was wondering the same last week⦠and found this on the same doc page that you linked:
set_mapped_ip_info_for_vm(*vm* )
Set configuration to possibly hide real IP from the VM. This needs to be done before executing āscriptā (/etc/xen/scripts/vif-route-qubes) in network providing VM
[source]
qubist
December 27, 2025, 7:12pm
3
@barto
Thanks for the feedback.
I wonder what is the assumed goal of hiding real IP address from the VM.
This way you can have several VMs that think they have the same IP (for example generic 192.168.1.1), but networking still works without conflicts.
qubist
December 28, 2025, 12:15pm
5
@marmarek
Is it just for conflict prevention? Any other supposed usage?
Just trying to figure possibilities.
unman
December 28, 2025, 12:44pm
6
Also allows you to hide true internal IP in case of compromise.
qubist
December 28, 2025, 1:09pm
7
@unman
Yeah, I thought about it already, but in that case wouldnāt it make sense that all VMs hide it by default?
unman
December 30, 2025, 2:36pm
8
By default, to what?
All qubes? To what benefit?
As a security measure, the only benefit I see is hiding the 10.137 and
10.138 giveaway but this is very minor - so many other Qubes tells.
qubist
December 31, 2025, 9:36am
9
@unman
10.0.0.1, or 192.168.0.1, or whatever safe value in regards to a case of potential compromise.
Not āallā as in āallā but as in āall by defaultā.
Benefit - the same one you mentioned.
Atrate
January 2, 2026, 8:43pm
10
Also seems⦠difficult to even use it:
user@dom0 ~ % qvm-prefs test visible_ip 192.168.1.1
qvm-prefs: error: property 'visible_ip' on AppVM instance cannot be set
test is a ProxyVM here. Also did not work when it was NOT a ProxyVM.
qubist
January 3, 2026, 10:53am
11
@Atrate
Have you opened an issue?
Atrate
January 3, 2026, 10:55am
12
No, as I assume Iām just using it incorrectly. The complete lack of documentation does not help in using it the way itās intended, though
DVM
January 3, 2026, 11:16am
13
The right way to change this value is with qvm-features like so:
# Example with 192.168.0.100
qvm-features <qube> net.fake-ip 192.168.0.100
Which returns:
qvm-prefs <qube> visible_ip
192.168.0.100
Doc: qvm-features ā manage domainās features ā Qubes Admin client mm_9c733d84-2-ga5ea121 documentation
Atrate
January 3, 2026, 11:23am
14
Nice, this seems to work, thank you!
