I know that pulseaudio is a common problem with the archlinux template so my question isn’t really about how to go around this. I know that I am never going to need any audio input from VMs derived from this template ever. Is there a way for me to exclude pulseaudio? If not do you have any ideas on how to solve this?
Hey @ludovic! Thanks lot for the response. I’ll get around to creating the issue as soon as possible. Although now I’m getting
Qubes OS tools allowing to use a Qubes VM as a NetVM/ProxyVM
qubes/qubes-vm-pulseaudio 4.0.31-10
Pulseaudio support for Qubes VM
qubes/qubes-vm-utils 4.0.31-10
Common Linux files for Qubes VM.
qubes/qubes-vm-xen 4.8.5-27
Xen is a virtual machine monitor
--> Installing mandatory qubes packages...
error: target not found: qubes-vm-dependencies
make[1]: *** [Makefile:66: rootimg-build] Error 1
when I tail build-logs/template-archlinux.org. Do you have any ideas on this? Were you able to build the template successfully?
