I am a new user of this beautiful OS and in the process of studying I came across the following question. I created a StandAlone cube on fedora 38, installed the nordvpn cli VPN into it. Everything went great. After that, I wanted to provide internet from this cube to other cubes, put the appropriate check mark, but internet did not start to be provided. What could be the problem?
Can you ping an IP address (e.g. 1.1.1.1) from one of the linked qubes or does it only not work for domains when using a browser for example?
I executed the ping command. I got the following result:
64 bytes from 1.1.1.1: icmp_seq=1 ttl=58 time=121 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=58 time=105 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=58 time=103 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=58 time=125 ms
64 bytes from 1.1.1.1: icmp_seq=5 ttl=58 time=114 ms
64 bytes from 1.1.1.1: icmp_seq=6 ttl=58 time=117 ms
64 bytes from 1.1.1.1: icmp_seq=7 ttl=58 time=112 ms
64 bytes from 1.1.1.1: icmp_seq=8 ttl=58 time=109 ms
64 bytes from 1.1.1.1: icmp_seq=9 ttl=58 time=105 ms
64 bytes from 1.1.1.1: icmp_seq=10 ttl=58 time=109 ms
64 bytes from 1.1.1.1: icmp_seq=11 ttl=58 time=106 ms
64 bytes from 1.1.1.1: icmp_seq=12 ttl=58 time=104 ms
At the same time, the sites do not open through firefox.
Can you run the following command inside your VPN qube and retry to load a website from a qube using it as netvm?
sudo /usr/lib/qubes/qubes-setup-dnat-to-ns
Unfortunately, nothing has changed. I forgot to mention that I use Qubes OS 4.2 .
Moreover I have other qube which is appVM and I’ve setup VPN there in standard way via network manager and via this qube everything work normal.
This could be due to the way the application handles network requests. Can you run both commands inside the VPN qube and share the output here?
sudo nft list ruleset
cat /etc/resolv.conf
Here it is:
table ip qubes {
set downstream {
type ipv4_addr
elements = { 10.137.0.18 }
set allowed {
type ifname . ipv4_addr
elements = { "vif15.0" . 10.137.0.18 }
chain prerouting {
type filter hook prerouting priority raw; policy accept;
iifgroup 2 goto antispoof
ip saddr @downstream counter packets 0 bytes 0 drop
chain antispoof {
iifname . ip saddr @allowed accept
chain postrouting {
type nat hook postrouting priority srcnat; policy accept;
oifgroup 2 accept
oif "lo" accept
masquerade
chain input {
type filter hook input priority filter; policy drop;
jump custom-input
ct state invalid counter packets 3 bytes 893 drop
iifgroup 2 udp dport 68 counter packets 0 bytes 0 drop
ct state established,related accept
iifgroup 2 meta l4proto icmp accept
iif "lo" accept
iifgroup 2 counter packets 0 bytes 0 reject with icmp host-prohibited
counter packets 1 bytes 266
chain forward {
type filter hook forward priority filter; policy accept;
jump custom-forward
ct state invalid counter packets 0 bytes 0 drop
oifgroup 2 counter packets 0 bytes 0 drop
chain custom-input {
chain custom-forward {
chain dnat-dns {
type nat hook prerouting priority dstnat; policy accept;
ip daddr 10.139.1.1 udp dport 53 dnat to 10.139.1.1
ip daddr 10.139.1.1 tcp dport 53 dnat to 10.139.1.1
ip daddr 10.139.1.2 udp dport 53 dnat to 10.139.1.2
ip daddr 10.139.1.2 tcp dport 53 dnat to 10.139.1.2
table ip6 qubes {
set downstream {
type ipv6_addr
set allowed {
type ifname . ipv6_addr
chain antispoof {
iifname . ip6 saddr @allowed accept
counter packets 7 bytes 508 drop
chain prerouting {
ip6 saddr @downstream counter packets 0 bytes 0 drop
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain _icmpv6 {
meta l4proto != ipv6-icmp counter packets 0 bytes 0 reject with icmpv6 admin-prohibited
icmpv6 type { nd-router-advert, nd-redirect } counter packets 0 bytes 0 drop
accept
chain input {
jump custom-input
iifgroup 2 goto _icmpv6
iif "lo" accept
ip6 saddr fe80::/64 ip6 daddr fe80::/64 udp dport 546 accept
meta l4proto ipv6-icmp accept
chain forward {
jump custom-forward
table ip qubes-firewall {
chain forward {
type filter hook forward priority filter; policy drop;
iifname != "vif*" accept
ip saddr 10.137.0.18 jump qbs-10-137-0-18
chain prerouting {
iifname != "vif*" ip saddr 10.137.0.18 drop
chain postrouting {
type filter hook postrouting priority raw; policy accept;
oifname != "vif*" ip daddr 10.137.0.18 drop
chain qbs-10-137-0-18 {
accept
reject with icmp admin-prohibited
table ip6 qubes-firewall {
chain forward {
chain prerouting {
chain postrouting {
table ip filter {
chain INPUT {
type filter hook input priority filter; policy accept;
iifname "vif13.0" ct mark 0xe1f1 counter packets 0 bytes 0 accept
iifname "eth0" ct mark 0xe1f1 counter packets 1448 bytes 794288 accept
iifname "vif13.0" counter packets 0 bytes 0 drop
iifname "eth0" counter packets 27 bytes 1248 drop
chain OUTPUT {
type filter hook output priority filter; policy accept;
oifname "vif13.0" meta mark 0x0000e1f1 counter packets 0 bytes 0 ct mark set mark
oifname "vif13.0" ct mark 0xe1f1 counter packets 0 bytes 0 accept
oifname "eth0" meta mark 0x0000e1f1 counter packets 1878 bytes 391256 ct mark set mark
oifname "eth0" ct mark 0xe1f1 counter packets 1881 bytes 392560 accept
oifname "vif13.0" counter packets 0 bytes 0 drop
oifname "eth0" counter packets 1 bytes 73 drop
table ip6 filter {
chain INPUT {
iifname "eth0" ct mark 0xe1f1 counter packets 0 bytes 0 accept
iifname "eth0" counter packets 0 bytes 0 drop
chain OUTPUT {
oifname "eth0" meta mark 0x0000e1f1 counter packets 0 bytes 0 ct mark set mark
oifname "eth0" ct mark 0xe1f1 counter packets 0 bytes 0 accept
oifname "eth0" counter packets 0 bytes 0 drop
table inet qubes-nat-accel {
flowtable qubes-accel {
hook ingress priority filter
devices = { eth0, lo, nordlynx, vif15.0 }
chain qubes-accel {
type filter hook forward priority filter + 5; policy accept;
meta l4proto { tcp, udp } iifgroup 2 oifgroup 1 flow add @qubes-accel
counter packets 294 bytes 23035
nameserver 10.139.1.1
nameserver 10.139.1.2
Was the VPN active when you ran these commands? If not, run them again with it connected to a server.
From what I can see of the results of your commands, it doesn’t seem to be changing the DNS or adding any related rules to nftables.
Just in case, I executed this command “sudo net list ruleset” again. The result of the second command is exactly the same as it was before. Now I’m sure that the VPN is turned on. Here is the result:
table ip qubes {
set downstream {
type ipv4_addr
set allowed {
chain prerouting {
chain antispoof {
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain input {
jump custom-input
ct state invalid counter packets 1 bytes 40 drop
iif "lo" accept
counter packets 2 bytes 266
chain forward {
jump custom-forward
chain dnat-dns {
table ip6 qubes {
set downstream {
type ipv6_addr
set allowed {
chain antispoof {
chain prerouting {
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain _icmpv6 {
accept
chain input {
jump custom-input
iif "lo" accept
chain forward {
jump custom-forward
chain forward {
chain prerouting {
chain postrouting {
chain forward {
chain prerouting {
chain postrouting {
table ip filter {
chain INPUT {
iifname "eth0" ct mark 0xe1f1 counter packets 2261 bytes 1364833 accept
iifname "eth0" counter packets 31 bytes 12971 drop
chain OUTPUT {
oifname "eth0" meta mark 0x0000e1f1 counter packets 2614 bytes 465105 ct mark set mark
oifname "eth0" ct mark 0xe1f1 counter packets 2614 bytes 465105 accept
oifname "eth0" counter packets 749 bytes 59115 drop
table ip6 filter {
chain INPUT {
chain OUTPUT {
oifname "eth0" counter packets 4 bytes 224 drop
Based on this link, they seem to use 103.86.96.100 and 103.86.99.100 for their DNS.
Can you run the following commands and test your clients again?
sudo nft flush chain ip qubes dnat-dns
sudo nft add rule ip qubes dnat-dns meta l4proto { tcp, udp } ip daddr { 10.139.1.1, 10.139.1.2 } th dport 53 dnat to 103.86.96.100
sudo nft add rule ip qubes dnat-dns meta l4proto { tcp, udp } ip daddr { 10.139.1.1, 10.139.1.2 } th dport 53 dnat to 103.86.99.100
Yup! Ths a lot! That’s really work!
After a while, unfortunately, I found that the solution described above partially solves the problem. Internet did appear on Qubes that receive Internet from a VPN Qube, but unfortunately it turned out that there is an unknown traffic leak. That is, I enabled killswitch feature in the VPN Qube, and when there is a discount from the VPN, there is no traffic leak on the VPN Qube itself, but in some incomprehensible way, the Internet continues to flow to Qubes connected to the VPN Qube, and the Internet naturally goes neither through the VPN provider, but directly from the sys-net. Maybe someone has an idea how it works?
This would mean that the killswitch provided by your VPN provider is not 100% leak-proof. If it still accepts traffic to be forwarded even outside the VPN tunnel, then this is a problem with how they handle their firewall system. If done correctly, everything should be locked down and no packets should be able to go anywhere after they reach the system running the VPN application. You should probably use the Qubes firewall as a last resort to try to limit the leaks.
It’s quite possible that the killswitch only operates on traffic
originating from the VPN host, and not traffic which is routed
through the qube.
This may not be any reflection on the provider,depending on how they
expect the VPN to be used.
Without knowing more details of the provider and your set up it’s
difficult to speculate.
In the end, I found out that the best way to use VPN with qubes is to use the built-in qube service - network-manager for adding VPN profile and for killswitch is to use built-in qube firewall rules. In this case, everything works as it should
