Pros and cons of using standalones as disposable templates
Hi everyone,
I’ve been considering a method for creating disposable sys-* VMs, and I’d love to hear your thoughts on it.
In many cases, I prefer to use a custom template for each disposable. I want to keep root filesystems minimal to reduce attack surface and I aim to avoid installing proprietary (thus untrusted) firmware like sys-net firmware on other VMs’ templates.
This results in a separate template being used for each sys-* VM, which kind of defeats the point of Qubes’ template-based approach. To simplify, I thought of condensing the usual
TemplateVM → AppVM (disposable template) → DispVM
setup to
StandaloneVM → DispVM.
Some advantages I can think of are
  • Fewer VMs overall (no intermediate AppVM), reducing clutter.
  • Easier management since both root and home are managed in one place.
  • Might slightly reduce the startup time and resource overhead of the disposable (?)
I’ve found that setting template-for-dispvms to true for a standalone VM works well. For security, I also set its netVM to none. The standalone can access the update proxy by enabling updates-proxy-setup and giving it appropriate RPC permissions.
I haven’t seen any discussion on this approach though. Are there any reasons to avoid it? Any security concerns I should be aware of?
This ensures that running software in the AppVM won’t affect your root system persistently.
This does not.
The approach in Qubes is to compartmentalize as much as possible, not the other way around.
That said, I agree that having many templates is a burden.
I don’t think it’ll have any advantage here.
One reason could be that backup would be bloated because you’ll need to backup the whole standalone compared to just AppVM (disposable template) if you use salt/bash scripts and don’t back up templates but recreate them when restoring the backup.
Also some template updates may require you to reinstall the template to apply some changes that couldn’t be applied by the packages update.
