This post is about a new project that provides bash completion for Qubes OS commands (also called tab completion).
I hope that it will be a part of Qubes OS at some point (after testing, improvements, code reviews and etc.). But even now the script works incredibly well according to my estimation.
Awesome, really. But the code is huge, and we know: more code - more places to make mistakes.
Currently I would like some users to try it and provide feedback, so that obvious problems will be found.
If you know bash, it will be an advantage, as you would be able to review the code or provide feedback.
Be aware that for proper testing the script should be installed (by simple copying) in dom0, and it is very recommended not to run anything un-trusted there.
Feel free to try and provide feedback. Additional help would be appreciated (e.g. writing test-cases, or code reviewing)
You can also help in a different way - by reading documentation below and providing text improvements or, perhaps, ideas for better implementation based on provided examples.
Here is the current state of docs:
qubes-completion - Bash tab completion for Qubes OS commands
What the project does
Project qubes-completion provides typing completions and hints for commands specific to Qubes OS operation system by completing all flags and arguments, qube names, firewall rules, devices, prefs, features, tags, packages and etc.
Typing completion is provided for almost all commands starting with qvm- and qubes- prefixes and several others.
While the project is expected to be the most valuable for advanced users who frequently use terminal in Qubes OS to manage the system, it can also be useful for average users. To use bash completions user should press Tab key once or twice when typing commands in terminal that runs bash.
What is supported
The project supports completion for:
1. Qube names (VM names):
$ qvm-firewall sys-<TAB><TAB>
sys-firewall sys-net sys-whonix
Running states of qubes are respected, e.g. provide only halted qubes for qvm-start:
$ qvm-start <TAB><TAB>
work sys-whonix fedora-37
Also classes (types) of qubes are used, like TemplateVMs and DispVMs:
$ qvm-create --template <TAB><TAB>
debian-11 fedora-37 fedora-37-minimal
2. All flags of commands (long and short versions):
$ qvm-ls --raw-<TAB><TAB>
--raw-data --raw-list
$ qvm-ls -<TAB><TAB>
--all --help -o --spinner
-d --help-columns -O -t
--disk --help-formats --paused --tags
--exclude -k -q --tree
--fields --kernel --quite -v
--format -n --raw-data --verbose
-h --network --raw-list
--halted --no-spinner --running
3. Predefined arguments (e.g. column names, colors of qubes and etc.):
$ qvm-ls --raw-data --fields=<TAB><TAB>
CLASS FLAGS MEMORY PRIV-CURR PRIV-USED ROOT-MAX STATE
DISK GATEWAY NAME PRIV-MAX ROOT-CURR ROOT-USED
$ qvm-block <TAB><TAB>
attach detach list
4. Firewall rule management (including rule numbers with hints)
$ qvm-firewall sys-firewall <TAB><TAB>
add del list reset
$ qvm-firewall sys-firewall add <TAB><TAB>
action= dst6= dstports= icmptype= specialtarget=
dst4= dsthost= expire= proto=
$ qvm-firewall sys-firewall del -<TAB>
=> qvm-firewall sys-firewall del --rule-no=
$ qvm-firewall sys-firewall del --rule-no=<TAB><TAB>
NO ACTION HOST PROTOCOL PORT(S) SPECIAL TARGET ICMP TYPE EXPIRE COMMENT
0 accept 1.1.1.1/32 tcp 443 - - - -
1 accept 200.200.200.200/32 udp 443 - - - -
2 accept 222.222.222.222/32 udp 80 - - - -
3 drop 111.111.111.111/32 udp 443 - - - -
4 drop 111.111.111.112/32 udp 443 - - - -
5 drop 111.111.111.113/32 udp 443 - - - -
6 drop 92.168.0.2/16 udp 443 - - - -
7 drop 192.168.0.0/16 tcp 81-90 dns - - -
8 drop - icmp - dns 7 +1905s -
9 drop 92.168.0.2/16 icmp - dns 6 +99905s -
10 drop 111.111.111.114/32 udp 443 - - - -
11 drop - - - - - - -
$ qvm-firewall sys-firewall del --rule-no=1<TAB><TAB>
5. Device IDs with name hints for all types (block, usb, pci and mic).
$ qvm-block attach sys-usb <TAB><TAB>
dom0:sda WDC_SOMEDISK () sys-usb (read-only=no, frontend-dev=xvdx)
dom0:sdb WORK_SOMEDISK ()
dom0:sdb1 WORK_SOMEDISK () work (read-only=no)
cryptvm:dm-0 somecrypt1 work (read-only=no, frontend-dev=xvdf)
cryptvm:dm-4 somecrypt5 personal (read-only=no)
$ qvm-device block detach work <TAB><TAB>
6. Property names (prefs), actual and common values for them
$ qvm-prefs personal <TAB><TAB>
audiovm installed_by_rpm name uuid
autostart ip netvm vcpus
backup_timestamp ip6 provides_network virt_mode
debug kernel qid visible_gateway
default_dispvm kernelopts qrexec_timeout visible_gateway6
default_user keyboard_layout shutdown_timeout visible_ip
dns klass start_time visible_ip6
gateway label stubdom_mem visible_netmask
gateway6 mac stubdom_xid xid
guivm management_dispvm template
icon maxmem template_for_dispvms
include_in_backups memory updateable
$ qvm-prefs personal label <TAB><TAB>
black blue --default gray green orange purple red yellow
$ qvm-prefs personal klass <TAB><TAB>
AdminVM AppVM --default DispVM StandaloneVM TemplateVM
7. Common qube features
qvm-features work gui<TAB>
gui gui-default-allow-utf8-titles gui-emulated
$ qvm-features --<TAB><TAB>
--D --default --delete --help --quite --unset --verbose
8. Tags of qubes
$ qvm-tags sys-firewall <TAB><TAB>
add del list set unset
$ qvm-tags sys-firewall del <TAB><TAB>
audiovm-dom0 created-by-dom0 guivm-dom0
9. Pool names:
$ qvm-create -P <TAB><TAB>
linux-kernel varlibqubes vm-pool
Note that volume-completion features currently are not available because qvm-volume tool is not optimized and executes too slow for providing responsive completions. If it gets optimized it will be possible to provide proper completion for volumes, too.
10. Arguments and flags provided by dnf for qubes-dom0-update:
$ sudo qubes-dom0-update --action=<TAB><TAB>
alias distro-sync install reinstall search
autoremove downgrade list remove shell
check group makecache repoinfo swap
check-update help mark repolist updateinfo
clean history module repoquery upgrade
deplist info provides repository-packages upgrade-minimal
$ sudo qubes-dom0-update --<TAB><TAB>
--action= --disableexcludes --noplugins
--advisories --disableplugin --obsoletes
--advisory --disablerepo --preserve-terminal
--allowerasing --downloaddir --quiet
--assumeno --downloadonly --randomwait
--assumeyes --enableplugin --refresh
--best --enablerepo --releasever
--bugfix --enhancement --repo
--bz --errorlevel --repofrompath
--cacheonly --exclude --repoid
--check-only --excludepkgs --rpmverbosity
--clean --force-xen-upgrade --sec-severity
--color --gui --secseverity
--config --help --security
--console --help-cmd --setopt
--cve --installroot --show-output
--debuglevel --newpackage --showduplicates
--debugsolver --noautoremove --skip-broken
--destdir --nodocs --verbose
--disableexcludepkgs --nogpgcheck --version
$ sudo qubes-dom0-update --en<TAB>
--enableplugin --enablerepo --enhancement
11. Packages for qubes-dom0-update (limited)
Note: Currently Qubes OS (as of R4.1) does not have dnf databases of packages and repos available for installation inside dom0, so it is not possible to provide completion of them (unlike inside other qubes).
If the situation with dnf databases in dom0 ever changes and completion of repos and packages for both dnf and qubes-dom0-update will start to work well out of the box.
Currently the project provides completion of packages that are possible to remove:
$ qubes-dom0-update --action=remove gtk-<TAB>
gtk-murrine-engine-0.98.2-18.fc32.x86_64
gtk-unico-engine-1.0.3-0.15.20140109bzr152.fc32.x86_64
gtk-update-icon-cache-3.24.28-2.fc32.x86_64
gtk-xfce-engine-3.2.0-11.fc32.x86_64
12. And more…
See yourself.
List of supported commands
Currently completion is provided for Qubes OS commands listed below.
Symbol * marks commands that have completion with limited implementation or a room for improvement.
qvm-lsqvm-tags-
qvm-start* qvm-shutdownqvm-killqvm-runqvm-pauseqvm-unpause-
qvm-create* qvm-cloneqvm-removeqvm-deviceqvm-blockqvm-usbqvm-pciqvm-prefsqvm-features-
qvm-volume* qvm-checkqvm-firewallqvm-serviceqvm-sync-appmenus-
qvm-appmenus* qvm-copy-to-vmqvm-move-to-vmqvm-copyqvm-moveqvm-start-guiqvm-start-daemonqvm-xkillqvm-sync-clockqvm-get-imageqvm-get-tinted-imageqvm-console-dispvm-
qubes-dom0-update* qubes-prefsqubes-guidqubes-hcl-reportqubes-bug-reportqubes-policyqubes-vm-settingsqubes-vm-clonequbes-vm-boot-from-devicequbes-input-triggerqubes-guivm-session-
qubesctl* -
qubesd-query*
How to install and use
1. Install bash-completion
The first step is to install bash-completion. To do so run in terminal of dom0:
$ sudo qubes-dom0-update -y bash-completion
Explanation: the project qubes-completion requires bash-completion. For some reason bash-completion package is not installed in dom0 by default in Qubes OS R4.0 and R4.1 (that may be changed in the future releases). Project bash-completion is great and installed in almost all GNU/Linux distributions out of box, so it worth installing it whether you plan to use qubes-completion or not.
2. Install qubes-completion
Currently qubes-completion does not belong to any package but can be copied as a file to dom0 and saved as
/etc/bash_completion.d/qubes-completion.sh.
To copy it from some qube user should run in terminal of dom0 something like:
$ qvm-run --pass-io qubename 'cat /home/user/Downloads/qubes-completion.sh' | sudo tee '/etc/bash_completion.d/qubes-completion.sh' | wc -l
Where:
qubenameis a name of the qube used to downloadqubes-completion.shscript (e.g.personal). -
/home/user/Downloads/qubes-completion.shis an example of full path to the downloaded file insidequbenameqube.
As the output user should see a number of lines that where copied and it should not be zero.
All done
Completions should start working in all new instances of bash terminals.
About the code
Code style
The code uses style guide from Google:
Shell Style Guide
It is used for everything except indentation which is 4 spaces and no tabs.
The code was verified with a great bash script checker ShellCheck using a FLOSS extension for Codium/VS Code, thanks to the authors, it helped a lot.
Notes on structure of the code
Shebang is not used for bash completion scripts, it is absent on purpose.
Execution is started with the function
main()at the end of the script. -
All completion functions are named after the commands, but with underscores.
E.g. for completion ofqvm-createthe_qvm_create()function is called.
All functions initialize specificQubes OScompletion model
by calling__init_qubes_completion()function.
Tests
The project has tests that are performed by BATS
(Bash Automated Testing System).
Tests are located in test/tests sub-directory.
Testing bash completions in general is not that easy.
Unlike bash completion project that uses python and other third-party stuff
to run tests the current project has it in Bash.
The magic of test preparation and execution is done by functions in file
test/tests_common.sh that make Bash completion variables look the same as
they are prepared by Bash in the terminal (using GNU function in C).
The approach also allows to generate tests (see test/tests_generator.sh).
Note that there still can be differences in parsing, so created tests should
be checked manually before using.
Generation of tests and manual checks of the expected results is required.
If tests are created for all supported functions it will ensure that further
changes are not breaking things. It is important because completion logic
for Qubes OS is quite a complicated thing.
Debugging
The project has debug-related stuff. Debug mode is managed by
DEBUG_MODE variable that is set to “0” by default (debug turned off).
Setting it to “1” makes debug code executable, otherwise it is skipped.
File debug_overrides.sh and stubs for qvm-* tools
Main script on the execution checks the existence of debug_overrides.sh file,
and if it exists it is sourced. The example of debug_overrides.sh is provided.
This way if debug output to log is not needed user can remove or rename
debug_overrides.sh file and avoid modification of the source code.
Also copying the project script alone to other places will automatically turn
debug mode off as it is desired by default.
So, the proper way to turn debug mode on is not a direct modification of
the main script, but overriding in debug_overrides.sh file, that also can
have paths to stub versions of qvm- tools that do not exist outside of dom0.
Check out the provided example of debug_overrides.sh for better understanding.
Debug functions
The script has general logging functions that allow to debug the completion
using extensive step-by-step real-time logging to an external log file:
Log a message to the log file if debug mode is on:
__debug_msg() -
Log an array to the log file if debug mode is on
(similar to declare -p but cleaner and works with refs):
__debug_print_array() -
Log all BASH completion variables to the log file if debug mode is on:
__debug_log_env()
When arguments are changed for Qubes OS tools
When arguments or flags of Qubes OS tool were changed the completion script
should be changed accordingly. The starting point of making such modifications
should be the function that corresponds to the changed tool.
E.g. _qvm_create() function for qvm-create tool.
In most cases the strings with the list or arguments and flags are located
inside these functions where they are used, and not in one place at the top
of the file with some constant strings for all commands.
The rationality of this choice:
Despite the fact that idea of keeping all strings in one place looks appealing,
it’s actually makes harder to support such code. The developer still needs to
scroll to the place where the string is used and analyze how modification of
flags or arguments will affect the code. So keeping the strings in one place
of the file not only does not make it easier the support of the code, but also
requires one to keep two distant places of the code coherent and consistent. -
The better approach is to keep the strings in place responsible for
the corresponding command that uses them - the completion function
with almost the same name as a command changed. -
Please note, that code still follows DRY principle and in some cases common
strings are still moved away just to avoid redefinition and duplicates.
Note: look the chapter about tests in this document. Because tests should be
a great help for monitoring of correctness of such code modifications.
Additional notes
The project tries not to use short versions of flags and arguments of common
third-party terminal tools and Bash builtin commands.
It allows to be more explicit, readable and error-proof.
The completion is expected to be quite smart, but it is not trying to
completely validate the way user calls functions.
Is many cases the inappropriate or misplaced arguments or flags will not be
provided to prevent user from calling something wrong, but there are still
millions of ways to call the commands improperly.
So, consider this completion script as an assistant, not a master.
Qubes OS tools has a specific thing in their syntax:
- The arguments for flags can be provided after both “=” char and space.
- And the value of the argument also can contain “=” char (maybe multiple?).
It makes impossible to parse commands in usual and general way, e.g. consider:
qvm-example --foo bar=baz
It’s impossible to say if --foo is followed by bar=baz value or
option bar has baz value.
So, to parse the command line some additional info is required (e.g. from docs).
It’s a minor design problem and complicates the script a bit, but what can we do.
The better design would to avoid separation of name=something values with “=”,
replace that with “:” (as it is already used in some commands) or something else.
