Hi I tryed to install Dbeaver on Fedora template.
First I enabled the LAN to wget the RPM
second I installed java
and then I installed the RPM all was OK no error.
I close the terminal and open the Setting and move the DBeaver from left side to the right side.
Now I can see it on the VM menu, but if I click on it nothing happen, so I try opening the VM terminal and call dbeaver but got command not found.
Any suggestion ?
Thanks
After a few restart is working
