There seems to be something wrong with the way my Qubes (DispVMs, AppVMs and TemplateVMs all affected) start:
If I start a Qube while another hasn’t fully completed the start-up process, both will fail every time. I “identify” this by looking at the RAM usage: Once it’s over 400 MB (assumimg default values), I’m safe to start the next one.
Only the preconfigured sys-net, sys-firewall, sys-whonix and sys-usb Qubes correctly start on boot. If I enable any other Qube to start on boot, it tries and fails.
Restarting after an update only works if either only a single Qube is affected or if it’s only the preconfigured sys-net, sys-firewall, sys-whonix and/or sys-usb.
When trying to update (using the GUI tool) more than one Qube at a time, either all or all but one Qube fail. If they’re already running when I start the update, it succeeds.
If a service Qube that’s not preconfigured starts because of another Qube that needs it to run (for example sys-vpn), it fails.
I’m running a clean reinstall of Qubes 4.2.1 on a ThinkPad T430 with 16 GB RAM and an i7-3840QM, but the same problems were there when I still had the i5-3320M.
As you can imagine, this makes using Qubes extremely cumbersome, so I’d greatly appreciate any help! Thank you:)
