Problem with sys-net dirs persistence
Hi everyone one, I’ve a problem with sys-net service that none of the dirs exist are persistent…I tired to make a script on /rw/config that actually execute some nmcli operations to connect into wifi with a stored SSID and pass, and it’s fully work when I execute it alone…and also made it as autorun through /rw/config/rc.local and it’s somehow doesn’t even save that commend even I did everything with sudo ( I mean it’s store’s that commend at that time but when I restart the whole laptop it’s disappear)
Does anyone have a solution for that ?
When configuring Qubes OS after installation, did you select “Make sys-net disposable”? You can check by pasting the output of qvm-ls | grep sys-net executed in dom0 here.
Oh yeah…
It’s a dispVM
should i make it non-disposable ?
If you want persistence, it’s going to have to be an AppVM and not a DispVM.
Once you make it an AppVM, you can make it selectively persistent (only certain files/directories) via custom-persist. How to make any file persistent (bind-dirs) — Qubes OS Documentation
thanks brother, durring that time i sent last message, i searched a bit and fixed everything, thanks )) sys-net was configured as dispvm, i had to make a new qube and name it sys-net and switch some other stuff, beside the post forgot to mention to disallow the autorun for the old sys-net qube and check it for the new one)) now the /rw/config scipt runned sucessfully and it’s connected imminently to the network ))
See also:
