Hi dear Qubes OS Community,
I hope this is the correct section here for my two problems.
I have a problem to copy files between VMs. It doesn’t seem to matter which VMs it is. The result is always the same? The clipboard shows me the correct messages if I do the following:
Ctr. + C / Ctrl. + shift + C / Ctrl. + Shift + V
But when I try to insert the file with “Ctrl. + V”, I get the error message that there is no such file in the directory. The VMs run of course
What could that be?
My second problem is installing files in Fedora:
I tried to install Comodo Antivirus. Of course the Linux version
It’s a “.rpm” file
I can unzip the file with the terminal. But don’t install. I have tried almost all possible commands for .rpm files in Feodra that I have found on the internet. I also looked at the documentation on the Qubes OS page. But maybe someone can explain to me what the problem could be. I admit that Linux commandos are new to me.
Many thanks in advance
