Hello, after restoring my bios to factory settings by mistake on a lenovo t480, I can’t boot into my partition. However, I manage to boot on the bootable USB key to use the QUBESOS rescue tool. My partition is detected, but when I enter my password it says: You don’t have any linux partition
Did you install Qubes OS in UEFI mode?
If yes then you need to boot from Qubes OS installer USB in rescue mode and add the EFI entry, assuming /dev/nvme0n1 is your Qubes disk and Qubes OS EFI partition number on this disk is 1: efibootmgr -c -u -L Qubes -l /EFI/qubes/xen.efi -d /dev/nvme0n1 -p 1
Check your BIOS settings and make sure to set them according to Qubes OS requirements.
If the problem persists then check the rdsosreport.txt for more detailed errors.
You need to boot in UEFI mode to change EFI entries.
You can use efibootmgr tool from another LiveUSB (for example, from Fedora LiveUSB) if you can’t boot Qubes OS installer in UEFI mode.
