Thanks for your answer. I don’t have any services there. Could this be due to my disposable VM setup?
After some tinkering I figured out how to do it:
# Disable network-manger system tray applet via dom0 terminal
qvm-service sys-usb network-manager --disable
# Verifiy that network-manager is off for sys-usb
qvm-service sys-usb --list
This isnt right.
In 4.1 the Services tab does not show default settings for services.
The default setting is for the network-manager service to be enabled in
qubes with “provides network” enabled, and no netvm. Otherwise the
service is disabled.
In either case, nothing will show on the Services tab, as @wilsonb found.
@wilsonb - you didnt say in what way you "modified " sys-usb, (or what
version of Qubes you are running). From the way you resolved this, my
guess would be that you enabled “provides network”, with no netvm.
