First of all I want to notify that I am complete beginner.
Having trouble installing 3isec-qubes-sys-vpn.x86_64 1.3-1.fc32 package on Qubes 4.1 beginning from the first step:
Install 1 Package
Total size: 11 k
Installed size: 11 k
Is this ok [y/N]: y
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : 3isec-qubes-sys-vpn-1.3-1.fc32.x86_64 1/1
Running scriptlet: 3isec-qubes-sys-vpn-1.3-1.fc32.x86_64 1/1
local:
Function: qvm.template_installed
Result: True
Comment: Template debian-11-minimal version 4.0.6 already installed
Started: 21:45:02.372848
Duration: 259.132 ms
Changes:
Function: qvm.clone
Result: True
Comment: /usr/bin/qvm-check template-openvpn None
Started: 21:45:02.632694
Duration: 12892.126 ms
Changes:
Function: qvm.features
Result: True
Comment: None
Started: 21:45:15.525503
Duration: 491.126 ms
Changes:
qvm.features:
default-menu-items:
new:
vpn_setup.desktop debian-xterm.desktop
old:
menu-items:
new:
old:
Function: qvm.start
Result: True
Comment: qvm.state running
Running None
Started: 21:45:16.016897
Duration: 11676.787 ms
Changes:
Summary for local
Succeeded: 4 (changed=1)
Failed: 0
Total states run: 4
Total run time: 25.319 s
template-openvpn: OK
[ERROR ] User 'user' is not available
local:
Result: True
Started: 21:46:07.249251
Duration: 254.597 ms
Changes:
Function: qvm.clone
Result: True
Comment: [SKIP] A VM with the name 'template-openvpn' already exists. None
Started: 21:46:07.504543
Duration: 283.224 ms
Changes:
Result: True
Comment: [SKIP] Feature already in desired state: SET 'menu-items' = vpn_setup.desktop debian-xterm.desktop
[SKIP] Feature already in desired state: SET 'default-menu-items' = vpn_setup.desktop debian-xterm.desktop None
Started: 21:46:07.788387
Duration: 61.328 ms
Changes:
Function: qvm.start
Result: True
Running None
Started: 21:46:07.849896
Duration: 72.738 ms
Changes:
ID: qvm-sync-appmenus template-openvpn
Function: cmd.run
Result: False
Comment: User 'user' is not available
Started: 21:46:07.926116
Duration: 3.809 ms
Changes:
Function: qvm.shutdown
Result: True
Comment: qvm.state halted
Halted None
Started: 21:46:07.930125
Duration: 5581.602 ms
Changes:
Function: qvm.present
Result: True
Comment: /usr/bin/qvm-create sys-vpn --class=AppVM --template=template-openvpn --label=green None
Started: 21:46:13.512302
Duration: 2500.802 ms
Changes:
Function: qvm.prefs
Result: True
Comment: None
Started: 21:46:16.013762
Duration: 1208.188 ms
Changes:
qvm.create:
maxmem:
new:
1000
old:
*default*
memory:
new:
300
old:
*default*
netvm:
new:
sys-firewall
old:
*default*
provides_network:
new:
True
old:
*default*
vcpus:
new:
2
old:
*default*
Result: True
Comment: None
Started: 21:46:17.222162
Duration: 748.612 ms
Changes:
qvm.features:
service.cups:
new:
old:
None
service.cups-browsed:
new:
old:
None
service.tinyproxy:
new:
old:
None
Result: True
Comment: [SKIP] Feature already in desired state: SET 'menu-items' = vpn_setup.desktop debian-xterm.desktop None
Started: 21:46:17.971084
Duration: 300.226 ms
Changes:
qvm.features:
default-menu-items:
new:
old:
None
Summary for local
Succeeded: 9 (changed=3)
Failed: 1
Total states run: 10
Total run time: 11.015 s
DOM0 configuration failed, not continuing
sys-vpn: OK
Verifying : 3isec-qubes-sys-vpn-1.3-1.fc32.x86_64 1/1
Installed:
Complete!
So as you can see there is some error with the user âuserâ.
When I ignored that error and tried to configure things by myself I faced another time wasting tries without having positive results.
- In template-openvpn missing the application vpn_setup.desktop which I downloaded from github manually to sys-vpn to be able to try steps described in unmanâs manual
- There was also missing zenity which I installed manually to sys-vpn using apt-get to be able perform install.sh
- There is an error when trying to open a console in sys-vpn qube (in template error is missing):
[FAILED] Failed to start Qubes misc post-boot actions.
- After spending about a week to find out problems and trying solve them but as I said I am a newbie in things like this so results was not positive. Unable even to ping any address from sys-vpn qube: network unavailable
Also I astonished a little that my openvpn config login and password are stored in vpn dirrectory as a pass.txt (or something similar). That looks kinda unsecure in my noob opinion.
In sum I think that the main problem is that the TemplateVM template-openvpn is based on Debian minimal but this is just my opinion.
Looking for support and step by step guide to make things come thru.
Thanks for your time!
