My network (ATT) allows connecting to xfinity.com using windows 11 and windows 10. For some reason, I get the following when attempting to connect using qubes ??
Thanks!
Larry Callis
I don’t think it’s qubes because it’s a operating system and as far as I know(I’m new to qubes though) qubes dosen’t do anything to effect that mabye its your browser?
“Access Denied / You don’t have permission” messages are issued by the destination site or its webhost, not by Comcast. It’s likely the site is blocking your public Comcast IP. You can look up your IP at Google Search You’ll probably need to ask the sites’ admins for help with this.
I guess the server thinks you’re a hacker and blocking you. maybe use tor to change your ip as long as they don’t block tor IPs you should be fine. That’s what I would try.
I had this one time with a website. Basically the web site had really restrictive rules to only allow a narrow user set. Probably due to your browser blocking something or anti fingerprinting option
