Hello everyone i want to create a standalone net-vm to use separately to setup a dhcp and dns server and testing it with a client vm for a school project , this is the procedure i followed:
attached the Usb wireless card to my new net-vm through sys-usb ;
ran $usb-devices command and checked if the firmware’s binary is present in /usr/lib/firmware;
ran $sudo modprobe mt7601u and $sudo demsg to check for errors;
ran $ip address and got the interface in a down state ;
ran $ip link set wlx001711024c26 up;
running $sudo iwlist wlx001711024c26 scan gave me the result i wanted ;
trying to connect i get the error “NetworkManager is not running.” ;
tried $sudo systemctl start NetworkManager no results ;
when running $sudo systemctl status NetworkManager i get
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─30_qubes.conf
Active: inactive (dead)
Condition: start condition failed at Thu 2024-01-11 23:15:35 +01; 2s ago
└─ ConditionPathExists=/var/run/qubes-service/network-manager was not met
thanks in advance ![]()
