I need a HVM in which i will have all type of personal information and it will be routed and used trough governmental sites, configuration and sensitive information so something like whonix I don’t think it will be acceppted or have the enough network speed to real-time work and high downloads.
From my personal view the best option I see is a distribution the most simple and the one i can trust that recollects the less data possible, do you know any distribution like this and where i can confirm its usage of data?
If it supports PVH it gets extra points, i say HVM as I expect this to be the faster option
have you looked into disposable vms? everything gets deleted once you shut it down (close the program you started it with)
I would need it at least /home persistant
Kicksecure? Effectively Whonix without tor.
After a long day reading about it, it definitely looks good, the only problem is that the .iso is not in stable version so i will do it in pvh then. Thank you.
You can just create a Debian-12 HVM and distro morph it into Kicksecure. Use the kicksecure-qubes-cli for more security features. It’s the same team behind Whonix.
See:
You are actually on the right place: the most private OS out there is Qubes OS, when you learn to use it.
Check any list, if you don’t believe me.
