I am super tired so I may be missing something obvious or not posting debug info that might be useful, so feel free to ask for whatever information may be helpful.
A couple nights ago, i accidentally yanked the power cord to my qubes os machine, so it suddenly shut down. after this, I was not able to connect to tor using anon-whonix (or any other qube networked through sys-whonix), whereas before I had no issues at all. I am, however, able to connect to the internet and do anything on the clearnet, so it seems that sys-net and sys-firewall are not affected, only sys-whonix.
anon-whonix sdwdate’s status shows:
Last message from anon-whonix sdwdate:
Preparation not done yet. More more information, see: sdwdate-gui → right click → Open sdwdate’s log
When I opened sdwdate’s log, it shows this:
2025-09-06 00:49:00 - sdwdate - INFO - PREPARATION: running onion-time-pre-script...
__ ### START: ### /usr/libexec/helper-scripts/onion-time-pre-script
__ Status: Subsequent run after boot.
__ Static Time Sanity Check: Within minimum time 'Mon Jul 21 00:00:00 UTC 2025' and expiration timestamp 'Tue May 17 10:00:00 UTC 2033', ok.
__ Tor Bootstrap Result:
check_bootstrap_helper_script: tor-circuit-established-check
tor_bootstrap_timeout_type:
tor_circuit_established_check_exit_code: 124
__ ### END: ### Exiting with exit_code '1' indicating 'wait, show error icon and retry.'.
2025-09-06 00:49:00 - sdwdate - INFO - PREPARATION RESULT: onion-time-pre-script detected a known permanent (until the user fixes it) error status. Consider running systemcheck for more information.
I then ran systemcheck:
[workstation user ~]% systemcheck
[INFO] [systemcheck] anon-whonix | Whonix-Workstation | whonix-workstation-17 TemplateBased AppVM | Sat Sep 6 01:58:48 AM UTC 2025
[INFO] [systemcheck] Tor Connection Result:
Tor's Control Port could not be reached. Attempt 1 of 5. Could be temporary due to a Tor restart. Trying again...
Tor's Control Port could not be reached. Attempt 2 of 5. Could be temporary due to a Tor restart. Trying again...
Tor's Control Port could not be reached. Attempt 3 of 5. Could be temporary due to a Tor restart. Trying again...
Tor's Control Port could not be reached. Attempt 4 of 5. Could be temporary due to a Tor restart. Trying again...
[ERROR] [systemcheck] Tor Connection Result:
Tor's Control Port could not be reached!
Troubleshooting:
- Confirm that Whonix-Gateway is running.
- Run systemcheck on Whonix-Gateway and confirm success.
- Rerun systemcheck here in this Whonix-Workstation.
(Technical information:)
(tor_circuit_established_check_exit_code: 124)
(tor_bootstrap_timeout_type: )
(tor_bootstrap_status: )
(check_socks_port_open_test: 28)
(Tor Circuit: not established)
zsh: exit 1 systemcheck
Then, i went to sys-whonix and opened the tor control panel. The tor status seems to hang on “Starting” and the progress bar displays 0%. I let this run for atleast 10 minutes with no change. If i go to the logs section in the tor control panel, I just see this:
Sep 06 02:02... [notice] New control connection opened.
Sep 06 02:03... [notice] New control connection opened.
If I go to sys-whonix’s sdwdate log, it shows this:
2025-09-06 01:44:41 - sdwdate - INFO - PREPARATION: running onion-time-pre-script...
__ Tor reports: NOTICE BOOTSTRAP PROGRESS=0 TAG=starting SUMMARY="Starting"
__ Tor circuit: not established
__ Tor Consensus Time Sanity Check: Consensus time sanity check failed.
__ anondate_use: Running 'anondate-set' (by creating file '/run/sdwdate/request_anondate-set')...
__ ### END: ### Exiting with exit_code '2' indicating 'wait, show busy icon and retry.'.
2025-09-06 01:44:41 - sdwdate - INFO - PREPARATION RESULT: onion-time-pre-script recommended to wait. Consider running systemcheck for more information.
Running systemcheck in sys-whonix shows the following:
[gateway user ~]% systemcheck
[INFO] [systemcheck] sys-whonix | Whonix-Gateway | whonix-gateway-17 TemplateBased ProxyVM | Sat Sep 6 02:05:36 AM UTC 2025
- Connecting for 0 seconds. | 0 % done.
- Tor Circuit: not established.
- Tor reports: NOTICE BOOTSTRAP PROGRESS=0 TAG=starting SUMMARY="Starting"
- Timesync status: not done.
- sdwdate reports: Preparation not done yet. More more information, see: sdwdate-gui -> right click -> Open sdwdate's log
- onion-time-pre-script reports:
- Connecting for 2 seconds. | 0 % done.
- Connecting for 4 seconds. | 0 % done.
It continues to repeat the same thing every two seconds, but im snipping it there for length sake.
I have tried rebooting already (several times), I have manually verified that everything’s netvm is set correctly, via both the qubes manager and dom0’s cli. I also completely deleted my original sys-whonix and remade it from the template, so the sys-whonix I am doing this debugging on is practically brand new. I was also trying to use chatgpt last night to debug, and I had it make me a report of everything that was done, which I am going to paste here:
Qubes OS Networking Debug Report: sys-whonix Connectivity Failure
Summary of the Problem
After a sudden power loss, the sys-whonix Qube lost network functionality. Following the incident:
sdwdate and onion-time-pre-script report failure to connect to Tor.
Manual attempts to restore networking (e.g. ip link set ... up, systemctl restart qubes-network) were ineffective.
Recreating sys-whonix from the whonix-gateway-17 template did not solve the issue.
The new sys-whonix instance also reports:
"ERROR: check network interfaces Result: network interface eth0 not up!"
Meanwhile:
sys-net and sys-firewall have confirmed working connectivity (ping 8.8.8.8 successful).
sys-whonix shows no default route, and interfaces are often DOWN or in /32 mode.
Likely Root Cause
One or more of the following is likely:
Virtual NIC misconfiguration or failure to attach between sys-whonix and its NetVM.
Qubes networking stack (qubes-core-agent-networking) is not initializing properly in sys-whonix.
Dom0 metadata became inconsistent after the power failure.
Possible missing udev/network triggers during Qube startup (especially after cloning or recreating the Qube).
Previous Fix Attempts
Manually brought up interfaces using ip link set eth0 up.
Restarted qubes-network systemd service.
Verified and reconfigured NetVM chain (to ensure sys-whonix → sys-firewall → sys-net).
Recreated sys-whonix from clean template.
Ran systemcheck and confirmed failures due to lack of networking.
Observed nslookup and ping failures in sys-whonix.
Recommended Debug Steps (Post-Reboot Checklist)
Verify NetVM Chain from dom0
I used this summary just tonight to try to get chatgpt to fix my errors but it just kept going in circles and getting nowhere. it seemed convinced I had some issue with my routing tables, so ill post some of that info here.
on sys-whonix:
[gateway user ~]% ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:16:3e:5e:6c:00 brd ff:ff:ff:ff:ff:ff
inet 10.137.0.9/32 scope global eth0
inet 10.0.2.15/24 brd 10.0.2.255 scope global eth0
inet 10.138.21.13/24 scope global eth0
3: eth1: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether b6:15:59:46:64:0c brd ff:ff:ff:ff:ff:ff
inet 10.137.0.9/32 brd 10.255.255.255 scope global eth1
4: vif3.0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether fe:ff:ff:ff:ff:ff brd ff:ff:ff:ff:ff:ff
[gateway user ~]% ip r
10.138.21.0/24 dev eth0 proto kernel scope link src 10.138.21.13
on sys-firewall:
[user@sys-firewall ~]$ ip a
inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group 1 qlen 1000
inet 10.138.21.12/32 scope global eth0
inet6 fd09:24ef:4179::a8a:14e2/128 scope global
inet6 fe80::216:3eff:fe5e:6c00/64 scope link proto kernel_ll
3: vif6.0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group 2 qlen 1000
inet 10.138.21.12/32 scope global vif6.0
inet6 fe80::fcff:ffff:feff:ffff/64 scope link proto kernel_ll
6: vif9.0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group 2 qlen 1000
inet 10.138.21.12/32 scope global vif9.0
[user@sys-firewall ~]$ ip r
default via 10.137.0.7 dev eth0 onlink
10.137.0.7 dev eth0 scope link
10.137.0.9 dev vif6.0 scope link metric 32746
10.138.4.119 dev vif9.0 scope link metric 32743
I ran a command to try and set sys-whonix’s default gateway to 10.137.0.7 while troubleshooting with chatgpt, but it said it was invalid:
[gateway user ~]% sudo ip route add default via 10.137.0.7 dev eth0
Error: Nexthop has invalid gateway.
zsh: exit 2 sudo ip route add default via 10.137.0.7 dev eth0
it did have me make some changes to the routing tables, before my browser suddenly closed and I lost access to the chat log, so im not super sure exactly what all I did, but I do know it made me flush the routing table or something similar (i think, half asleep so my memory isnt great).
Any idea where to go from here?
