Portable QubesOS - dynamic vm pci assignment
o/
I’m using QubesOS on an USB stick as a portable solution.
Since portable goes hand in hand with differing systems and devices I ran into some issues.
The most annoying one, remapping attached devices to my network vm.
Therefore, I automated it.
code: script
#!/bin/bash
set -eo pipefail
[[ $EUID -ne 0 ]] && { echo "Run as root" >&2; exit 1; }
SYS_UUID=$(dmidecode -s system-uuid)
BOARD_NAME=$(dmidecode -s baseboard-product-name)
BOARD_SERIAL=$(dmidecode -s baseboard-serial-number)
echo "Running on SYS_UUID: $SYS_UUID (BOARD_NAME: $BOARD_NAME - BOARD_SERIAL: $BOARD_SERIAL)"
declare -A PCI_ASSIGNMENT
if [[ "$SYS_UUID" == "9f0dc5f0-84dd-4c7d-ac1a-97c6f2e8be26" ]]; then
    echo "Config: System N"
    #PCI_ASSIGNMENT["first-vm"]="dom0:00_01.2 dom0:00_02.0"
elif [[ "$SYS_UUID" == "2f42f0d2-6771-459a-b921-ef1ffd55cb91" ]]; then
    echo "Config: System N+1"
    #PCI_ASSIGNMENT["first-vm"]="dom0:00_01.4"
    #PCI_ASSIGNMENT["a-second-vm"]="dom0:00_01.5"
else
    echo "Config: Fallback"
fi
check_vm() {
    local vm_name="$1"
    local state
    state=$(qvm-ls -O STATE "$vm_name" 2>/dev/null | tail -n +2)
    if [[ -z "$state" ]]; then
        echo "Error: VM $vm_name does not exist" >&2
        return 1
    fi
    if [[ "$state" == "Halted" ]]; then
        return 0
    fi
    echo "Error: $vm_name is running, cannot modify PCI assignments" >&2
    return 1
check_device() {
    local pci="$1"
    local -a available
    mapfile -t available < <(qvm-pci ls 2>/dev/null | tail -n +1 | awk '{print $1}')
    for entry in "${available[@]}"; do
        [[ "$entry" == "$pci" ]] && return 0
    done
    echo "Error: PCI device $pci not found in system" >&2
    return 1
get_unassignments_delta() {
    local -n _pci_assignment="$1"
    local vm_name="$2"
    local -a current
    mapfile -t current < <(qvm-pci ls --assignments "$vm_name" 2>/dev/null | tail -n +1 | grep "$vm_name" | awk '{print $1}')
    local -a intended
    read -ra intended <<< "${_pci_assignment[$vm_name]}"
    for pci in "${current[@]}"; do
        local found=0
        for intended_pci in "${intended[@]}"; do
            [[ "$pci" == "$intended_pci" ]] && found=1 && break
        done
        [[ $found -eq 0 ]] && echo "$pci"
    done
get_assignments_delta() {
    local vm_name="$2"
    local -a current
    local -a intended
    for pci in "${intended[@]}"; do
        local found=0
        for current_pci in "${current[@]}"; do
            [[ "$pci" == "$current_pci" ]] && found=1 && break
        done
    done
unassign() {
    local vm_name="$1"
    echo "Unassigning pci devices from $vm_name"
    qvm-pci unassign "$vm_name"
assign() {
    local vm_name="$1"
    local pci="$2"
    echo "Assigning $pci to $vm_name"
    qvm-pci assign -r -o no-strict-reset=True "$vm_name" "$pci"
verify_assignments() {
    local error=0
    for vm in "${!PCI_ASSIGNMENT[@]}"; do
        check_vm "$vm" || error=1
        read -ra pci_ids <<< "${PCI_ASSIGNMENT[$vm]}"
        for pci in "${pci_ids[@]}"; do
            check_device "$pci" || error=1
        done
    done
    return $error
apply_assignments() {
        local -a to_unassign
        mapfile -t to_unassign < <(get_unassignments_delta PCI_ASSIGNMENT "$vm")
        if [[ ${#to_unassign[@]} -gt 0 ]]; then
            unassign "$vm"
        fi
        local -a to_assign
        mapfile -t to_assign < <(get_assignments_delta PCI_ASSIGNMENT "$vm")
        for pci in "${to_assign[@]}"; do
            assign "$vm" "$pci"
        done
    done
verify_assignments || { echo "not applying changes - exiting script">&2; exit 1; }
apply_assignments
code: service
[Unit]
Description=dynamic assignment of pci devices to vms
After=qubesd.service
Before=qubes-vm@.service
[Service]
Type=oneshot
ExecStart=/where/did/i/put/my-script.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
code: qubesd-config
[Unit]
After=my-custom.service
Requires=my-custom.service
If you want to adapt the solution:
  1. run the script and it will output your system uuid
    1.1. at the top of the script you can with that uuid distinguish between system configuration
  2. add the per-system config as: PCI_ASSIGNMENT["first-vm"]="dom0:00_01.2 dom0:00_02.0"
  3. that line would remove all other pci device of the vm and attach the specified ones
I recommend to only follow until here and just run+verify the config manually on your systems
  1. add the systemd service
  2. put qubesd-config on /etc/systemd/system/qubes-vm@.service.d/after-dyn-assign.conf
With that systemd integration we run the script each time QubesOS boots and chain it between the necessary qubesd.service and the startup of the configured vms.
Great idea! I’ve also tried using Qubes OS portably, but on the same machine. If I get the chance to use it across different hardware, I’ll definitely use these instructions. Thanks for sharing!
