(see usage notes at bottom)
A script to make it possible to reach a qube its port through the external interface of the qubes-os host, with undo functionality.
I am writing out what seems to be the “essential” parts of the script.
In long-form, to hopefully make them easier to understand (for people unfamiliar with the ip command).
A long form that was less clean to me, was ctstate.
Which is a list of connection states to match, see man iptables-extensions.
Initially:
comment="$( printf \''PortFwd %s:%s%s'\' "${qube?}" "${protocol?}" "${port?}" )"
iptables \
--insert INPUT 5 \
--protocol ${protocol?} \
--destination-port ${port?} \
--match conntrack \
--ctstate NEW \
--jump ACCEPT \
--match comment \
--comment "${comment?}"
And then traverse all the network providing qubes as well,
passing on packets from incoming to outgoing (ip) address with:
comment="$( printf \''PortFwd %s>%s:%s%s'\' "${from_qube?}" "${to_qube?}" "${protocol?}" "${port?}" )"
iptables \
--table nat \
--append PREROUTING \
--in-interface ${incomingPacketInterface?} \
${incomingPacketRecipient:+--destination ${incomingPacketRecipient?}} \
--jump DNAT \
--to-destination ${outgoingPacketRecipient?} \
--match comment \
iptables \
--insert FORWARD 2 \
--in-interface ${incomingInterface?}
--match conntrack \
--ctstate NEW \
--jump ACCEPT \
--match comment \
nft add rule ip qubes-firewall forward meta iifname ${incomingInterface?} accept
This script didn’t work for me on Qubes 4.2-rc5. It errors with:
$ qvm-portfwd-iptables.sh --action create --qube myDestQube --port 22066
myDestQube: Allowing input to port 22066
/bin/bash: line 1: iptables-save: command not found
/bin/bash: line 1: iptables-restore: command not found
/bin/bash: line 1: iptables: command not found
/bin/bash: line 1: ifconfig: command not found
sys-firewall: Forwarding on port 22066 to myDestQube (10.138.11.174 → 10.137.0.17)
Error: syntax error, unexpected accept
add rule ip qubes-firewall forward meta iifname accept
sys-net: Forwarding on port 22066 to sys-firewall (10.137.0.5 → 10.138.11.174)
I used this much more simple/elegant solution instead.
