qqubes
January 4, 2022, 10:00am
1
Occasionally I have seen the pointer start moving by itself when I am not touching the mouse or anything else on my laptop.
Unplugging the USB mouse and plugging it back in stops the pointer movement when this happens.
I have two other devices that move the pointer: a touchpad and a “mini-touchpad” in the middle of the keyboard so I suspect some kind of interference.
But I want to check if this is a potential security concern (e.g. someone or some illicit code is trying to control my mouse)?
ppc
January 4, 2022, 10:04am
2
have you checked all of your usb port?
if there nothing, check the mouse, it might difficult unless you have a “know good” usb mouse
This has happened to me with several os with a wireless usb mouse.
I don’t really know why but I suspect it is because I also have a touchpad maybe too sensitive.
In any case a simple ESC stops the movement of the cursor.
Sven
January 4, 2022, 6:53pm
4
@qqubes you might find this thread interesting.
qqubes
January 4, 2022, 8:43pm
5
Yes, fascinating! Perhaps I should share my relevant experiences in that thread, that happened on a different system.
But hopefully my observed pointer movement falls into the what you described there:
“If however the cursor simply jumps around randomly or moves straight to
one corner or edge and then stays there… another explanation is more
likely.”
qqubes
January 4, 2022, 8:44pm
6
Now that you mention it, I recall it happening once (pointer start drifting) when my USB mouse was not plugged in.
