Please vote for i2p in Qubes. Are there anyone interested?
Continuing the discussion from What is your opinion at Hyphanet (Freenet), and using Hyphanet on Qubes os?:
I want i2p like I’ve tor in Qubes. Why should I discuss Qubes question in Whonix forum?
Feel free to drop a reasonable answer, please.
PS: I’m rarely here, so what is a reasonable vote method inside the Qubes, not Whonix community?
Evaluating the interest and getting together a group of volunteers is perfectly on topic in “General Discussion”. If this becomes a project with sub-threads you should work with moderators to figure out if there should be a dedicated category or maybe a dedicated forum / mailing list. In other words one thread (this one) is ok, many threads about this need their own place.
When you compose a new post you should have the “Build poll” option under the gear icon. If you don’t your user level might not be high enough. In that case reach out to “moderators” and ask for the poll to be build for you. Just outline the question and the possible answers.
Was this a “reasonable answer”? :wink:
  • Yes
  • No
0 voters
This is not a task which should be asked of others; just make a new template and install i2p. I2pd is available through some repos and more complete packaging solutions are easily aqcuired with a little digging on the browser. This could all be done in less time than it would take for you to pull down a whole new template from the template manager, although configuration may take some time if you don’t know what you’re doing.
Hi all, it would be nice to have a generic VPN template which just uses a minimal template and all the network-manager something plugins to enable all sorts of VPN. So also not so much experienced users can go with their vpn provider. Maybe also with support for nested use of VPN-VMs that are derived from the VPN template.
Same can be done with I2P.
i finished doing netvm i2pd qube, in next some days i’ll provide guide for it
Yes very much so :wink:
I finished writing my guide. I2pd netvm guide
