I used the instructions in the Qubes documentation, and everything was working well until I got to stage 4. the first qube it tries to update is my Android template, however the update fails, I get this error message:
and the update process stops/fails without trying to update any other qubes. I would like to finish upgrading to v4.2 as soon as possible. What should I do?
Thanks in advance.
there is a flag to exclude HVM vm from upgrading, I think this is the same issue I had a while ago during a release candidate with an OpenBSD VM (don’t forget to make backups though)
my bad, you have to skip standalone VMs, not specifically HVM.
This is done by adding -k
Usage: qubes-dist-upgrade [OPTIONS]...
This script is used for updating current QubesOS R4.1 to R4.2.
Options:
--update, -t (STAGE 1) Update of dom0, TemplatesVM and StandaloneVM.
--release-upgrade, -r (STAGE 2) Update 'qubes-release' for Qubes R4.2.
--dist-upgrade, -s (STAGE 3) Upgrade to Qubes R4.2 and Fedora 37 repositories.
--template-standalone-upgrade, -l (STAGE 4) Upgrade templates and standalone VMs to R4.2 repository.
--finalize, -x (STAGE 5) Finalize upgrade. It does:
- resync applications and features
- cleanup salt states
--convert-policy, -p (STAGE 6) Convert qrexec policy in /etc/qubes-rpc/policy
to the new format in /etc/qubes/policy.d.
--all-pre-reboot Execute stages 1 to 3
--all-post-reboot Execute stages 4 to 6
--assumeyes, -y Automatically answer yes for all questions.
--usbvm, -u Current UsbVM defined (default 'sys-usb').
--netvm, -n Current NetVM defined (default 'sys-net').
--updatevm, -f Current UpdateVM defined (default 'sys-firewall').
--skip-template-upgrade, -j Don't upgrade TemplateVM to R4.2 repositories.
--skip-standalone-upgrade, -k Don't upgrade StandaloneVM to R4.2 repositories.
--only-update Apply STAGE 4 and resync appmenus only to
selected qubes (comma separated list).
--keep-running List of extra VMs to keep running during update (comma separated list).
Can be useful if multiple updates proxy VMs are configured.
--max-concurrency How many TemplateVM/StandaloneVM to update in parallel in STAGE 1
(default 4).
