I am a big fan of Qubes Minimal Templates (Fedora and Debian) and have been using them for years. I am quite familiar with them to the point that most of my VM templates and standalones are minimal ones. However, I have never been able to figure out what these two packages do:
see the ‘Description’ field of the following commands:
sudo dnf info qubes-desktop-linux-common
[user@dom0 ~]$ sudo dnf info qubes-desktop-linux-common
Qubes OS Repository for Dom0 2.9 MB/s | 3.0 kB 00:00
Installed Packages
Version : 4.2.3
Release : 1.fc37
Architecture : noarch
Source : qubes-desktop-linux-common-4.2.3-1.fc37.src.rpm
Repository : @System
From repo : qubes-dom0-cached
Summary : Common code used for multiple desktop environments' Qubes
: integration
URL : http://www.qubes-os.org
License : GPL
Description : Common code used for multiple desktop environments' Qubes
: integration
sudo dnf info qubes-menus
[user@dom0 ~]$ sudo dnf info qubes-menus
Installed Packages
Version : 4.2.3
Release : 1.fc37
Summary : Configuration and data files for the desktop menus
License : GPL
Description : This package contains the XML files that describe the menu layout
: for GNOME and KDE, and the .desktop files that define the names
: and icons of "subdirectories" in the menus.
These packages are installed in dom0, not in the templates (minimal or not).
(You can confirm this with: sudo dnf list --installed, in dom0 and in the templates)
Awesome! Thanks a lot, I did not know about the info subcommand of dnf. Since I was wondering if I needed it for my minimal template setup, my question is answered.
