I am trying to reinstall Qubes, as I believe my current installation has become compromised. I have already created a bootable USB stick. However, when I attempt to boot from the USB stick, I get a plain grub menu, with no option to install Qubes.
Before creating the bootable USB stick, I used a Chromebook to format the USB stick. Now I’m wondering if this resulted in the USB being formatted in such a way that it is not recognized by my PC. Could this be the problem? Or is something else not working?
How did you create the installation media?
Did you verify that the Qubes OS ISO is not corrupted?
Verifying signatures | Qubes OS
Did you re-verify installation media after writing?
With the dd command. Would an app such as Etcher also work?
Yes, I checked the signature and the checksum. The release signing key had different values from what’s posted on the Qubes website. I already asked about this on the forum,
Yes, but I will try again
Hello! For the next person finding this post:
I had the same issue, and my problem was that when I wrote the ISO to the USB stick, I used the partition /dev/sda1 instead of the full disk /dev/sda. Once I fixed that and rewrote the ISO, it worked.
