user2
September 14, 2020, 10:46pm
1
Hello, the pgadmin4 server configuration is lost on reboot. I need to configure a connection to my server again each time. Does anyone know how to fix this?
I tried these bind-dirs, no result.
binds+=( '/var/lib/pgadmin' )
binds+=( '/var/log/pgadmin' )
unman
September 15, 2020, 2:44am
2
When you say “no result”, what do you mean?
Are the relevant directory structures created in /rw/bind-dirs?
Aren’t there some config files in /etc/pgadmin that you need to retain?
user2
September 15, 2020, 6:58am
3
Thank you for your answer.
“no result” means that the pgadmin server still needs to be reconfigured on reboot. The two mentioned structures are created in /rw/bind-dirs.
There is no /etc/pgadmin folder. Checked before and after reconfiguring the pgadmin server.
My guess is that there is another configuration file that needs to be added to bind-dirs.
user2
September 17, 2020, 4:11pm
4
The pgadmin started to “remember” my server configurations after several reboots. Do not know why.
