My machine has an external usb NIC attached, which I use for network connections in sys-usb. I added this device with the --persistent flag so it automatically attaches to sys-net anytime the system boots.
However, it seems sys-usb is started after sys-net and prevents sys-net to boot up correctly.
Is there some way to force sys-net to wait for sys-usb before starting?
What type of trouble shooting do you have in mind? Currently, the system boots up just fine. Its just that sys-net and sys-firewall don’t come up on boot. If I start them after logged into the UI, everything works.
Qubes 4.0 with kernel-latest. The NIC is a cheap noname one.
I don’t think the NIC itself is the problem. I haven’t tried yet, but I think this problem would occur with whatever usb device you connect to sys-net when using a usb vm. The problem is that sys-usb is started after sys-net. usb devices can only be attached after sys-usb has started, so sys-net is damned to fail in this case.
How is Qubes determining the start order of other vms? it seems the “NetVM” property implicitely defines such an order.
