Persistent attach of device with varying backend name
I am trying to persistently attach a device which has a varying backend name.
This is the guide that I followed to get the backend name
It returns something like “dm-85”, but it changes with each boot, so I cant do qvm-block attach -p vmname dom0:dm-85 since it won’t exist on next boot.
I can script it to attach it on boot, but then if I restart a VM it won’t be attached anymore.
What could be some solutions?
Could you use cron or systemd to periodically check if the VM is running, and if it is, to then attach the device?
Use libxl hook as I’ve suggested in another topic:
sudo mkdir /etc/libvirt/hooks/
cat << 'EOF' | sudo tee /etc/libvirt/hooks/libxl >/dev/null
#!/bin/bash
guest_name="$1"
libvirt_operation="$2"
if [ "$guest_name" = "yourqubename" ] && [ "$libvirt_operation" = "started" ]; then
        exec 0</dev/null
        exec 1>/dev/null
        exec 2>/dev/null
        dev=$(basename $(readlink /dev/YOUR_LVM_VG/YOUR_LVM_IMAGE))
        if ! qvm-block attach "$guest_name" dom0:$dev; then
            qubesdb-write /qubes-block-devices/$dev/desc "YOUR_LVM_IMAGE"
        fi
    ) & disown
fi
EOF
sudo chmod +x /etc/libvirt/hooks/libxl
Thank you, works like a charm
Some tips for future readers, to debug you can restart libvirtd manually instead of rebooting completely, systemctl restart libvirtd
exit 0 as quickly as possible if it’s not your target operation/VM
the subshell and redirection of output seems to prevent locking/hanging, if it’s not used the VM wouldn’t boot properly, probably for the same reason a terminal might hang until you hit cancel. And if that happens you can barely kill the VM because it’s in a locked state
look for alternative faster qvm- tools like qubesdb-read rather than qubes-block ls, any time wasted in the hook is time lost on boot
Some useful links here
https://wiki.archlinux.org/title/Libvirt#Hooks
My script is highly personalized with personal device names and VM names, so not useful for the public, but I hope this helps someone else solve the same issue :slight_smile:
Thank you very much, this was exactly what I was looking for.
Maybe this can be merged into a community guideline.
