Paused and hidden disp qubes
Hi there.
I’ve freshen installed v.4.3 (and tested downloaded iso before usb making and at boot internal integrity check before install).
So, after first update and reboot, I see 2 paused disp qubes [attached images: disp972 & disp1612].
Can You explain me why there’ re there?
And why Qube Manager doesn’t show them, but qvm-ls -t (or xentop) does?
Thanks a lot.
Cheers.
This is intended behavior as part of the Preloaded Disposables feature:
You wanna more of them???
Go Global Config > General > Preload disposable qubes > setting the given count of 2 a bit higher…
No, seriously, what I wanna say is - if you don’t need them, just set the count there to Nil and thats it…
That’s not the first time this issue appears on the forum, and I think that there is no way to understand what is going on from the UI, so I’m putting the needs-issue tag.
It’s not a bug, it’s a feature!
I’m sure it would present a whole lot of horrible race conditions and other problems, but I would love to be able to change the names of my disposables while they are running.
It would also offer a clean way of marking why the preload vms are there… with no need for extra user docs.
Tag removed :slight_smile:
Hi there,
yes it’s the first thing I disable on my qubes!
:sweat_smile:
Can you please explain why? Did you ever use them? I’d like to to know what can be improved.
briefly, as always, for a laptop:
  • faster boot/shutdown
  • resource control
  • philosophy: I hate Windows management, so I dislike if other *nix behave the same way.
    If I want a disposable, I want to launch it when I need it and not by system choice.
    Cheers.
