Parrot os
So i tried using parrot os in a standalone vm with a iso but there are a few things that i dont know how to fix
i see my mouse double
my internet doesnt connect
also it wont let me use the clipboard across other qubes
is there anything similar to qubes windows tools for this
To get ParrotOS with working integration into Qubes you can:
  1. Use ParrotOS template from unman repo:
    https://qubes.3isec.org/
  2. Copy and morph debian-13 template into ParrotOS
*You can block file and clipboard access to/from this qubes.
but i want it as a desktop environment like windows is that possible or not?
For internet to work inside HVM look at this official docs guide
It’s Debian based distro. What’s the issue with just getting the list of packages which it has and installing them into a new Debian template?
