In the latest Qubes upgrade, a really cool panel featured appear which I unfortunately deleted by mistake while editing my panel tab… Instead of having the classic “line by line” app launcher which lists everything came a better designed window sorting out apps and programs by types of VM’s. This is what I deleted and was unable to add back to the panel…
Any suggestion on how I can get that back ? I resorted to reinstall the old app launcher but this feels like a downgrade
Thanks, actually this is what I’ved used to restore the “old” applications Menu. By old I mean it shows as a launcher list with all applications whatsoever, uncategorised and unfiltered - like in the previous Qubes release which is somewhat less comfortable to go back to now.
The closest thing I could go back to the latest application menu (the one that shows app in a tree view as installed per VM) was to install “Whisker Menu”. It’s close but not exactly the same, as I get unwanted elements showing there like “Favorites”, Session name, Session log out option etc.
