abc
October 30, 2020, 9:45pm
1
Solution here and here for 4.0.3 do not work for “Pane is dead”. Is there another method to solve?
Thank you.
Plum
October 30, 2020, 10:32pm
2
Can you explain what the problem is and where you encountered it?
abc
October 30, 2020, 10:36pm
3
“X startup failed, aborting installation
The installation cannot continue and the system will be rebooted Press ENTER to continue”
“Pane is dead” is the result. Happens after you start installer.
Plum
October 30, 2020, 10:40pm
4
Maybe a Nvidia graphics card issue?
opened 10:15AM - 15 Aug 20 UTC
T: bug
C: installer
P: default
hardware support
affects-4.1
**Qubes OS version**
R4.0.3
**Affected component(s) or functionality**
Inst… aller
**Brief summary**
Everything works up until Qubes tries to start an X server.
**To Reproduce**
Steps to reproduce the behavior:
1. Boot from USB.
2. Choose whatever option you like.
3. Wait until the screen with 3 dots goes away. _Kinda awkward that this renders in my opinion._
4. See log in "Additional context."
**Expected behavior**
The X server starts successfully.
**Actual behavior**
The X server fails to start.
**Screenshots**
N/A
**Additional context**
- Secure boot is disabled.
- Legacy support is enabled.
- Legacy boot first is enabled.
<details>
Starting installer, one moment...
anaconda 25.20.9-1 for Qubes R4.0.3 started.
* installation for log files are stored in /tmp during the installation
* shell is available on TTY2
* if the graphical interface fails to start, try again with the inst.txt bootoption to start text installation.
* when reporting a bug add logs from /tmp as separate text/plain attachments
XX:XX:XX Not asking for VNC because we don't have a network
XX:XX:XX X startup failed, aborting installation
(Enter)
Pane is dead
archlinux
description: Notebook
product: 81UH (LENOVO_MT_81UH_BU_idea_FM_Legion Y740-15IRHg)
vendor: LENOVO
version: Lenovo Legion Y740-15IRHg
serial: MP1LENTF
width: 64 bits
capabilities: smbios-3.0.1 dmi-3.0.1 smp vsyscall32
configuration: administrator_password=disabled boot=normal chassis=notebook family=Legion Y740-15IRHg frontpanel_password=disabled keyboard_password=disabled power-on_password=disabled sku=LENOVO_MT_81UH_BU_idea_FM_Legion Y740-15IRHg uuid=6BDA9AE0-6F78-E911-8101-9C5A445184A0
*-core
description: Motherboard
product: LNVNB161216
vendor: LENOVO
physical id: 0
version: SDK0R32862 WIN
serial: MP1LENTF
slot: Type2 - Board Chassis Location
*-firmware
description: BIOS
vendor: LENOVO
physical id: 0
version: BVCN10WW(V1.06)
date: 06/06/2019
capacity: 10MiB
capabilities: pci upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb biosbootspecification uefi
*-cpu
description: CPU
product: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
serial: To Be Filled By O.E.M.
slot: U3E1
capacity: 4500MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
configuration: cores=6 enabledcores=6 threads=12
*-cache:0
description: L1 cache
physical id: 5
slot: L1 Cache
capacity: 384KiB
capabilities: synchronous internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 6
slot: L2 Cache
capacity: 1536KiB
configuration: level=2
*-cache:2
description: L3 cache
physical id: 7
slot: L3 Cache
capacity: 12MiB
configuration: level=3
*-memory
description: System Memory
physical id: 25
slot: System board or motherboard
*-bank:0
description: SODIMM DDR4 Synchronous 2667 MHz (0.4 ns)
product: RMSA3260ME78HAF-2666
vendor: Ramaxel
physical id: 0
serial: 136581AA
slot: ChannelA-DIMM0
width: 64 bits
clock: 2667MHz (0.4ns)
*-bank:1
vendor: Ramaxel
physical id: 1
serial: 1215A28D
slot: ChannelB-DIMM0
width: 64 bits
*-pci
description: Host bridge
product: 8th Gen Core Processor Host Bridge/DRAM Registers
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 07
width: 32 bits
clock: 33MHz
configuration: driver=skl_uncore
resources: irq:0
*-pci:0
description: PCI bridge
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
physical id: 1
bus info: pci@0000:00:01.0
version: 07
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:121 ioport:4000(size=4096) memory:50000000-640fffff ioport:92000000(size=1048576)
*-display
description: VGA compatible controller
product: TU104BM [GeForce RTX 2080 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:180 memory:63000000-63ffffff memory:50000000-5fffffff memory:60000000-61ffffff ioport:4000(size=128) memory:62000000-6207ffff
*-multimedia
description: Audio device
product: TU104 HD Audio Controller
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:17 memory:64000000-64003fff
*-usb
description: USB controller
product: TU104 USB 3.1 Host Controller
physical id: 0.2
bus info: pci@0000:01:00.2
version: a1
width: 64 bits
clock: 33MHz
capabilities: msi pciexpress pm xhci cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:143 memory:92000000-9203ffff memory:92040000-9204ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.8.1-arch1-1 xhci-hcd
physical id: 0
bus info: usb@3
logical name: usb3
version: 5.08
capabilities: usb-2.00
configuration: driver=hub slots=2 speed=480Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@4
logical name: usb4
version: 5.08
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-serial
description: Serial bus controller
product: TU104 USB Type-C UCSI Controller
physical id: 0.3
bus info: pci@0000:01:00.3
version: a1
width: 32 bits
clock: 33MHz
capabilities: msi pciexpress pm bus_master cap_list
configuration: driver=nvidia-gpu latency=0
resources: irq:145 memory:64004000-64004fff
*-generic:0
description: Signal processing controller
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
physical id: 4
bus info: pci@0000:00:04.0
version: 07
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
configuration: driver=proc_thermal latency=0
resources: irq:16 memory:92410000-92417fff
*-generic:1 UNCLAIMED
description: System peripheral
product: Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
physical id: 8
bus info: pci@0000:00:08.0
version: 00
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: memory:92424000-92424fff
*-generic:2
product: Cannon Lake PCH Thermal Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 10
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=intel_pch_thermal latency=0
resources: irq:16 memory:92425000-92425fff
*-usb
product: Cannon Lake PCH USB 3.1 xHCI Host Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 10
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
resources: irq:142 memory:92400000-9240ffff
*-usbhost:0
physical id: 0
bus info: usb@1
logical name: usb1
version: 5.08
configuration: driver=hub slots=16 speed=480Mbit/s
*-usb:0
description: Keyboard
product: ITE Device(8910)
vendor: ITE Tech. Inc.
physical id: 4
bus info: usb@1:4
version: 13.11
capabilities: usb-2.01
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:1
product: Corsair Gaming K95 RGB PLATINUM Keyboard
vendor: Corsai
physical id: 6
bus info: usb@1:6
version: 13.11
*-usb:2
description: Video
product: Integrated Camera
vendor: Chicony Electronics Co.,Ltd.
physical id: 7
bus info: usb@1:7
version: 0.27
serial: 0001
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:3
description: Bluetooth wireless interface
vendor: Intel Corp.
physical id: e
bus info: usb@1:e
version: 0.02
capabilities: bluetooth usb-2.00
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.08
configuration: driver=hub slots=8 speed=10000Mbit/s
*-memory UNCLAIMED
description: RAM memory
product: Cannon Lake PCH Shared SRAM
physical id: 14.2
bus info: pci@0000:00:14.2
version: 10
width: 64 bits
clock: 33MHz (30.3ns)
capabilities: pm bus_master cap_list
resources: memory:92420000-92421fff memory:92426000-92426fff
*-network
description: Wireless interface
product: Wireless-AC 9560 [Jefferson Peak]
physical id: 14.3
bus info: pci@0000:00:14.3
logical name: wlp0s20f3
version: 10
serial: a4:c3:f0:48:3a:14
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.8.1-arch1-1 firmware=46.8902351f.0 9000-pu-b0-jf-b0- ip=192.168.0.157 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:16 memory:92418000-9241bfff
*-serial:0
product: Cannon Lake PCH Serial IO I2C Controller #0
physical id: 15
bus info: pci@0000:00:15.0
version: 10
width: 64 bits
clock: 33MHz
configuration: driver=intel-lpss latency=0
resources: irq:16 memory:64100000-64100fff
*-serial:1
product: Cannon Lake PCH Serial IO I2C Controller #1
physical id: 15.1
bus info: pci@0000:00:15.1
version: 10
width: 64 bits
clock: 33MHz
resources: irq:17 memory:64101000-64101fff
*-communication:0
description: Communication controller
product: Cannon Lake PCH HECI Controller
physical id: 16
bus info: pci@0000:00:16.0
version: 10
width: 64 bits
clock: 33MHz
configuration: driver=mei_me latency=0
resources: irq:146 memory:92429000-92429fff
*-sata
description: SATA controller
product: Cannon Lake Mobile PCH SATA AHCI Controller
physical id: 17
bus info: pci@0000:00:17.0
version: 10
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:128 memory:92422000-92423fff memory:9242e000-9242e0ff ioport:5040(size=8) ioport:5048(size=4) ioport:5020(size=32) memory:9242d000-9242d7ff
*-pci:1
product: Cannon Lake PCH PCI Express Root Port #17
physical id: 1b
bus info: pci@0000:00:1b.0
version: f0
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:122 ioport:6000(size=8192) memory:94000000-aa0fffff ioport:70000000(size=570425344)
*-pci:2
product: Cannon Lake PCH PCI Express Root Port #21
physical id: 1b.4
bus info: pci@0000:00:1b.4
version: f0
width: 32 bits
clock: 33MHz
resources: irq:123 memory:92300000-923fffff
*-nvme
description: NVMe device
product: SAMSUNG MZVLB1T0HALR-000L2
vendor: Samsung Electronics Co Ltd
physical id: 0
bus info: pci@0000:3e:00.0
logical name: /dev/nvme0
version: 5L1QEXA7
serial: S3RSNA0M539249
width: 64 bits
clock: 33MHz
capabilities: nvme pm msi pciexpress msix nvm_express bus_master cap_list
configuration: driver=nvme latency=0 nqn=nqn.2014.08.org.nvmexpress:144d144dS3RSNA0M539249 SAMSUNG MZVLB1T0HALR-000L2 state=live
resources: irq:16 memory:92300000-92303fff
*-namespace
description: NVMe disk
physical id: 1
bus info: nvme@0:1
logical name: /dev/nvme0n1
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: guid=80d810a0-377f-2342-92ff-13cce4d78d76 logicalsectorsize=512 sectorsize=512 wwid=eui.00253885910a1ab4
*-volume:0 UNCLAIMED
description: Windows FAT volume
vendor: mkfs.fat
physical id: 1
bus info: nvme@0:1,1
version: FAT32
serial: 0a59-a3af
capacity: 1023MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat
*-volume:1
description: EFI partition
physical id: 2
bus info: nvme@0:1,2
logical name: /dev/nvme0n1p2
serial: cb61dc16-6723-43fa-87cf-0165d4153db9
capacity: 952GiB
width: 2954862648 bits
capabilities: encrypted luks initialized
configuration: bits=11544797240 filesystem=luks hash=sha256 version=2
*-pci:3
product: Cannon Lake PCH PCI Express Root Port #13
physical id: 1d
bus info: pci@0000:00:1d.0
version: f0
width: 32 bits
clock: 33MHz
resources: irq:124 ioport:3000(size=4096) memory:92200000-922fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:3f:00.0
logical name: enp63s0
version: 15
serial: 9c:5a:44:51:84:a0
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.8.1-arch1-1 duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.0.241 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:16 ioport:3000(size=256) memory:92204000-92204fff memory:92200000-92203fff
*-communication:1
product: Cannon Lake PCH Serial IO UART Host Controller
physical id: 1e
bus info: pci@0000:00:1e.0
version: 10
width: 64 bits
clock: 33MHz
resources: irq:20 memory:64102000-64102fff
*-isa
description: ISA bridge
product: Intel Corporation
physical id: 1f
bus info: pci@0000:00:1f.0
version: 10
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-multimedia
product: Cannon Lake PCH cAVS
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 10
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: irq:178 memory:9241c000-9241ffff memory:92100000-921fffff
*-serial:2
description: SMBus
product: Cannon Lake PCH SMBus Controller
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 10
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:16 memory:9242b000-9242b0ff ioport:5000(size=32)
*-serial:3
product: Cannon Lake PCH SPI Controller
physical id: 1f.5
bus info: pci@0000:00:1f.5
version: 10
width: 32 bits
clock: 33MHz
capabilities: bus_master
configuration: driver=intel-spi latency=0
resources: irq:0 memory:fe010000-fe010fff
*-pnp00:00
product: Motherboard registers
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
physical id: 2
capabilities: pnp
*-pnp00:02
physical id: 3
capabilities: pnp
*-pnp00:03
physical id: 5
capabilities: pnp
*-pnp00:04
product: AT Real-Time Clock
physical id: 6
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:05
product: PnP device INT3f0d
physical id: 7
capabilities: pnp
*-pnp00:06
product: IBM Enhanced keyboard controller (101/2-key)
physical id: 8
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:07
physical id: 9
capabilities: pnp
*-pnp00:08
physical id: a
capabilities: pnp
*-battery
description: Zinc Air Battery
product: CRB Battery 0
vendor: -Virtual Battery 0-
physical id: 1
version: 08/08/2010
serial: Battery 0
slot: Fake
*-power UNCLAIMED
description: OEM Define 1
product: OEM Define 5
vendor: OEM Define 2
physical id: 2
version: OEM Define 6
serial: OEM Define 3
capacity: 75mWh
</details>
**Solutions you've tried**
- I applied what I always did to get the Arch Linux installer to start: Add `nouveau.modeset=0` to the boot configuration.
- I consulted the [NVidia Troubleshooting Guide](https://www.qubes-os.org/doc/nvidia-troubleshooting/) and added `nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:off` to my boot configuration.
- I consulted [this](https://www.reddit.com/r/Qubes/comments/i6ey7x/qubes_installation_failure_x_startup_failed/) reddit post. Although I added `xdriver=nouveau` instead of `xdriver=intel`.
**Relevant [documentation](https://www.qubes-os.org/doc/) you've consulted**
- [NVidia Troubleshooting Guide](https://www.qubes-os.org/doc/nvidia-troubleshooting/)
**Related, [non-duplicate](https://www.qubes-os.org/doc/reporting-bugs/#new-issues-should-not-be-duplicates-of-existing-issues) issues**
N/A
Plum
October 30, 2020, 10:43pm
6
What is your setup? Qubes is pretty fussy. Anything non-standard and you’re screwed unless you’re technical enough to implement workarounds (I’m not).
abc
October 30, 2020, 10:45pm
7
Plum:
What is your setup?
For my settings to boot or my computer? It’s a Intel Nuc.
Plum
October 30, 2020, 10:47pm
8
abc
October 30, 2020, 10:52pm
9
Not sure which problem/solution there is exactly mine.
Plum
October 30, 2020, 11:04pm
10
Nor me - it’s likely to be something to do with your BIOS settings though. Hopefully someone who has installed Qubes on a Nuc will be able to help.
abc
October 31, 2020, 12:44am
11
Noticed this in the code: “if the graphical installation interface fails to start, try again with the inst.text bootoption to start text installation”.
*Did not work. Same error.
