Pairing android bluetooth earbuds
Trying to pair these airbuds with qubes on a librem laptop.
I know the laptop has Bluetooth, just wondering if there is gui for this? or i need to follow some command line tutorial.
This kind of GUI?
But you need to install firmware for it to work.
not sure why my combined sys-net is not saving the install
Have you installed it directly in sys-net or in its template?
i just installed blueman inside the fedora-37 template. but after restart, not getting any tray icon
is there more to it than blueman?
It should automatically install all dependencies and start on startup.
Though I tested it on fedora-36. Can’t speak for other templates.
Try running blueman-applet or blueman-tray manually from the commandline in your USB handling qube and see if anything changes.
