Hi all,
Is there anyway to replace the user login password (on KDE and xscreensaver) with a OTP? I’m familiar with the challenge-response option using Yubikey, but wondered if there was a OTP option.
Thanks as ever,
-ken
Hi all,
Thanks as ever,
-ken
It seems like a question not specific to Qubes OS, because dom0 (which shows the password prompt) runs Fedora. You could try to search/ask on their forums.
I didn’t try, but at first glance it looks ok and still up to date How to Set Up 2-Factor Authentication for Login and sudo - Linux.com
There’s a PR in the works for HOTP with NitroKey3:
