The issue occurred after performing an in place upgrade from R4.2 to R4.3.
Before, when first logging in, the operation execution window would just show
Operation: qubes.InputMouse.
After upgrading, it now shows
Operation: qubes.InputMouse+usb-XXXX+XXXX+
(It is longer on screen)
I could not find much information on this.
At a glance, it appears to be a USB controller ID added onto the normal operation. Is this the intended behaviour? Also, does this mean it is trying to use the whole USB controller for mouse input?
Thanks for the help.
I don’t use input devices but I think it was in the release notes:
Major features and improvements since Qubes 4.2: Dom0 upgraded to Fedora 41 (#9402)., Xen upgraded to version 4.19 (#9420)., Default Fedora template upgraded to Fedora 42 (Fedora TemplateVMs and St...
Linking to:
opened 08:31AM - 18 Feb 18 UTC
closed 10:20PM - 17 Sep 25 UTC
ux
P: default
pr submitted
C: input proxy
r4.2-vm-bookworm-stable
r4.2-host-stable
r4.2-vm-trixie-stable
r4.2-vm-fc41-stable
r4.2-stable
targets-4.3
r4.2-vm-fc42-stable
r4.3-vm-bookworm-stable
r4.3-stable
r4.3-vm-trixie-stable
r4.3-host-stable
r4.3-vm-fc41-stable
r4.3-vm-fc42-stable
r4.3-vm-fc43-stable
#### Qubes OS version:
R4.0rc4
### Steps to reproduce the behavior:…
With sys-usb and qubes-input-proxy-sender set up, start or resume a machine with a USB device which advertises keyboard capabilities but that you don't want to use in dom0.
### Expected behavior:
There should be a (supported) way to blacklist said device from being detected/used by qubes-input-proxy-sender.
### Actual behavior:
On my thinkpad T450s the integrated USB camera (04ca:703c Lite-On Technology Corp.) is picked up as a keyboard device by qubes-input-proxy-sender's udev rules (didn't have time to see why, but the question here is more general).
My qubes.InputKeyboard rpc policy is set to ask so each time I start or resume the laptop I get the gui popup asking if I want to enable a keyboard. With the laptop undocked I know that's the camera. But when the laptop's docked with an external keyboard I have no way to know which popup gui corresponds to the camera so I end up enabling everything.
### General notes:
Actually the issue here is two-fold:
* It would be helpful to have the name of the device in the rpc popup gui.
* There should be a way to either blacklist or whitelist input devices. If one considers sys-usb unsecure the best way place to do that would be in dom0, but I didn't find how to do that with the rather generic qubes.InputKeyboard rpc policy.
[__EDIT__: I realize that if sys-usb is considered insecure there's no way to be sure that the device name shown in dom0's popup gui is the right device's name. So that defeats the purpose of having the policy in dom0; That said I still think it would be helpful to have the name shown in the popup gui, maybe with a note that the name isn't trusted].
Workaround: in sys-usb's *template*, copy /lib/udev/rules.d/90-qubes-input-proxy.rules to /etc/udev/rules.d/90-qubes-input-proxy.rules (an identic naming will override the rules in /lib).
For blacklisting: add a goto line that matches your device near the top of the file:
ENV{ID_SOMETHING}=="somethingelse", GOTO="qubes_input_proxy_end"
For whitelisting: add ENV{whatever} to the systemctl lines so that they match *only* your devices(s).
#### Related issues:
