I host a OpenVPN server which I connect to using a .ovpn file called “config.ovpn”.
Before updating to the latest QubesOS version all I needed is to run: sudo openvpn config.ovpn
to route the entire Whonix VM’s traffic through the VPN.
When I try to do the same thing after updating it doesn’t work anymore.
I am unable to connect to any website when connected to the VPN. I cannot curl anything in the terminal.
And IRC clients cannot connect either.
What I am trying to achieve is this: Tor → VPN → Website
because I need to access websites that block Tor.
And I want to connect to the VPN inside the Whonix Workstation. NOT Whonix Gateway.
Because I want to be able to terminate the VPN connection and switch to Tor when the VPN is not needed.
