All community guides seems to be for R4.2 and wireguard.
I myself host many openvpn servers I need to create a vpn gateway for R4.3 that works with openvpn …
official guide is for openvpn but qubes 4.1 , which doesnt work for 4.2/4.3
You should be able to follow the wireguard network manager guide. You just need to manually add your credentials otherwise it should be same
I doubt it will work, but if you say there’s a chance no harm in asking the OP himself.
@solene does your guide Wireguard VPN setup work for Qubes 4.3 and openvpn ? I have a .conf file too but its for openvpn… and Im using r4.3 not 4.2…
No difference between 4.2 and 4.3 about this.
What about it being viable for OpenVPN ? the post is for wireguard vpn . can you confirm it does not work for openvpn?
solene did not reply but implied it doesnt work for openvpn (he/she started a new thread specifically for that)
