When opening Qube Settings while a disposable VM is shutting down, sometimes it doesn’t work and it comes up with the Houston… error. The details are below. Does this do anything bad to my computer?
line: 'Got empty response from qubesd. See journalctl in dom0 for '
func: _parse_qubesd_response
line no.: 81
file: /usr/lib/python3.5/site-packages/qubesadmin/base.py
line: return self._parse_qubesd_response(return_data)
func: qubesd_call
line no.: 597
file: /usr/lib/python3.5/site-packages/qubesadmin/app.py
line: payload_stream)
func: qubesd_call
line no.: 68
line: self.vm.name, 'admin.vm.feature.Get', item).decode('utf-8')
func: __getitem__
line no.: 55
file: /usr/lib/python3.5/site-packages/qubesadmin/features.py
line: return self[item]
func: get
line no.: 74
line: and not vm.features.get('internal', False))
func: _filter_internal
line no.: 31
file: /usr/lib/python3.5/site-packages/qubesmanager/utils.py
line: choice_list = list(choice_list)
func: prepare_choice
line no.: 81
line: *args, **kwargs)
func: prepare_vm_choice
line no.: 168
line: allow_default=True, allow_none=True)
func: __init_basic_tab__
line no.: 431
file: /usr/lib/python3.5/site-packages/qubesmanager/settings.py
line: self.__init_basic_tab__()
func: __init__
line no.: 168
line: settings_window = VMSettingsWindow(vm, qapp, args.tab)
func: main
line no.: 1318
line: load_entry_point('qubesmanager==4.0.45', 'console_scripts', 'qubes-vm-settings')()
func: <module>
line no.: 9
file: /usr/bin/qubes-vm-settings
