OpenBSD template
I’ve uploaded an OpenBSD template to https://qubes.3isec.org/ if any one
is interested.
If you want to give it a try, please read this page
You must set virt_mode to hvm, and initialise the private storage with
newfs sd1c on first boot.
You can configure networking in the qube using information from the
qube settings, and creating two files in /home/config to hold the IP
address and the netvm IP.
Otherwise it’s a vanilla OpenBSD install.
Thanks @unman
No support for qrexec and updates yet?
The link for OpenBSD template is broken:
wget https://qubes.3isec.org/rpm/r4.2/templates/qubes-template-OpenBSD-0.1-202503060322.noarch.rpm
--2025-03-19 16:37:19--  https://qubes.3isec.org/rpm/r4.2/templates/qubes-template-OpenBSD-0.1-202503060322.noarch.rpm
Resolving qubes.3isec.org (qubes.3isec.org)... 195.10.223.181
Connecting to qubes.3isec.org (qubes.3isec.org)|195.10.223.181|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2025-03-19 16:37:20 ERROR 404: Not Found.
Update: Link to rpm file is broken but installation using qvm-template worked.
That isnt the link to a template on the server: I dont know where you
got it from.
Use one or other of the methods on the templates page
Hello 09/2025
in what machine ? ( GC, and proc)? have you net connexion ?
