OpenBSD 8.0 was released yesterday.
I’ve shipped a new OpenBSD 8.0 template today, available from
https://qubes.3isec.org/Templates_4.3/
You can download or install using qvm-template. Instructions on that
page.
page.
Thank you! @unman For my actual sys-net i prefer Debian minimal, but good to play with OpenBSD and learn.
I wish your work was part of the official Qubes - templates, the TorVM etc.
Why is it still not?
Cause, If you can figure out how to verify @unman 's sig and sign his stuff then you are worthy to use its distros! ![]()
For that, one must at least be a forum reader. Those who are not would not even know such thing exists.
+1
Utmost respect to unman, but simply knowing
in Dom0 is not the only “barrier to entry”. If using Unix, not Linux, users would be wise to know the difference(s) at the very least imo. Desire no debate, just an opinion.
Still bravo! @unman and thanks for all your great work over these many, many years (decades?)!
Best regards…
I did not knew about Debian 14 minimal ![]()
Not so easy to replace me. ![]()
Are you officially linked to the Whonix / sys-whonix project?
Are you referring to this (last bullet)?
No, Just curious if we can ask it ‘sys-whonix’ questions if its official.
Finally a good question from @qubist
It has been awhile. Well done! Maybe you will get some insight if anyone
bothers to responds.
No offense @unman I respect you and your work. Thank you!
I only worry that making OpenBSD easy to install for forum readers, who
can’t or won’t learn how to build their own templates and become
comfortable installing 3rd party stuff in Dom0 is risky. Nevertheless
I appreciate you and your work.
Thank you unman!
Good luck and best intentions qubist.
No officially not. Just a huge fan, heavy user and bug submitter.
Thank you @unman I will install 8.0
Is OpenBSD secure?
That depends on your threat model.
Bears! ![]()
Did something change in the way DHCP works in 8.0 vs 7.9? I can’t get an address assigned when using this new version with same parameters.
pfctl -f /etc/pf.conf stalls with error
no IP address found for iwx0
/etc/pf.conf:9: could not parse host specification
pfctl: Syntax error in config file: pf rules not loaded
It fails on inet autoconf. ifconfig iwx0 shows connection to my router but no IP address. My router can also see OpenBSD.
If I replace inet autoconf with e.g. inet 192.168.1.111 in hostname.iwx0 then I can at least access local network but still no outside internet. ping 192.168.1.1 succeeds ping 1.1.1.1 fails with Can't assign requested address..
Relevant changes in:
Did I miss something?
Yes, I had to modify some rules compared to the previous version, but i am not with my OpenBSD device now to check my working rules.
So the fix in my case was simple and it turns out I was not at fault here.
The new template has a file /etc/dhcpleased.conf included that was absent in the 7.9 version. This file was causing dhcpleased service (DHCP lease daemon) to crash.
rcctl check dhcpleased returned dhcpleased(failed)
rcctl -d start dhcpleased would show a syntax error in in line 1 of dhcpleased.conf i.e. interface em0 ignore dns.
So DHCP was not working because the daemon was not running. Deleting this file fixed everything. I didn’t need to make any modifications to the config files.
Looking at dhcpleased.conf(5) - OpenBSD manual pages I have no idea why it says the syntax is bad. Or should it use {} brackets?
