How can I configure my disposable VMs to get a shell via “Run Terminal” in the icon “Qubes Domain” in my specific dispVM?
Every time I use the workaround to open a dom0 shell and execute the command qvm-run --user user dispXXXX xterm for getting a shell for my dispVM. For my appVMs I get a shell. There are no problems.
What should I do to get terminals via “Qubes Domain”-icon?
What’s this disposable VM template?
Do you have the same problem with non-disposable qubes?
Or qubes based on other templates?
Or disposables based on other templates?
Can you open File Manager from Qubes Domain widget or it doesn’t work as well?
