Hello,
I would like to use warpinator
No problem for the installation, but impossible to communicate with my local network
I followed this guide
Understanding firewalling in Qubes Every qube in Qubes is connected to the network via a FirewallVM, which is used to enforce network-level policies. By default there is one default FirewallVM, but the user is free to create more, if needed. For more...
But I get confused and do not understand the different ip I have to enter. (10.137.1.x then 10.137.0.x and again 10.137.2.y etc… ) So it does not work!
Is there someone who is familiar with the network to explain to me which ip I have to enter?
My config :
sys-net-wlan : vif : 10.137.0.27
wls6 : 192.168.1.5
sys-fw-wlan-in : vif : 10.137.0.30
eth0 : 10.137.0.30
AppVm Warpinator : 10.137.0.18
Local Network : 192.168.1.0/24
warpinator open port 42000 tcp and udp and 42001 tcp
Merci beaucoup :
Translated with www.DeepL.com/Translator (free version)
My “iptables”. Currently:
For sys-net-wlan :
$ ifconfig | grep -i cast
vif16.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.137.0.27 netmask 255.255.255.255 broadcast 0.0.0.0
vif18.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
vif22.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
vif24.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
wls6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.5 netmask 255.255.255.0 broadcast 192.168.1.255
[user@sys-net-wlan-in ~]$ sudo iptables -t nat -L PREROUTING -n --line-number
Chain PREROUTING (policy ACCEPT)
num target prot opt source destination
1 PR-QBS all -- 0.0.0.0/0 0.0.0.0/0
2 PR-QBS-SERVICES all -- 0.0.0.0/0 0.0.0.0/0
3 WARPINATOR tcp -- 0.0.0.0/0 192.168.1.5 tcp dpt:42000
4 WARPINATOR tcp -- 0.0.0.0/0 192.168.1.5 tcp dpt:42001
Chain FORWARD (policy DROP)
DROP all -- anywhere anywhere state INVALID
WARPINATOR tcp -- anywhere 10.137.0.30 tcp dpt:42001 ctstate NEW
WARPINATOR tcp -- anywhere 10.137.0.30 tcp dpt:42000 ctstate NEW
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
QBS-FORWARD all -- anywhere anywhere
For sys-fw-wlan-in :
$ sudo iptables -L -n
Chain INPUT (policy DROP)
DROP all -- 0.0.0.0/0 0.0.0.0/0 state INVALID
DROP udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:68
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0
REJECT all -- 0.0.0.0/0 0.0.0.0/0 reject-with icmp-host-prohibited
QBS-FORWARD all -- 0.0.0.0/0 0.0.0.0/0
WARPINATOR tcp -- 0.0.0.0/0 10.137.0.18 tcp dpt:42001 ctstate NEW
WARPINATOR tcp -- 0.0.0.0/0 10.137.0.18 tcp dpt:42000 ctstate NEW
Chain OUTPUT (policy ACCEPT)
Chain QBS-FORWARD (1 references)
Chain WARPINATOR (2 references)
ACCEPT all -- 192.168.1.0/24 0.0.0.0/0
[user@sys-fw-wlan-in ~]$ sudo iptables -t nat -L PREROUTING -n
WARPINATOR tcp -- 0.0.0.0/0 10.137.0.30 tcp dpt:42000
WARPINATOR tcp -- 0.0.0.0/0 10.137.0.30 tcp dpt:42001
$ sudo nft list table ip qubes-firewall
table ip qubes-firewall {
chain forward {
type filter hook forward priority filter; policy drop;
ct state established,related accept
iifname != "vif*" accept
ip saddr 10.137.0.18 jump qbs-10-137-0-18
chain qbs-10-137-0-18 {
ip daddr 192.168.1.0/24 accept
ip daddr 192.168.1.20 tcp dport 42001 accept
ip daddr 192.168.1.20 tcp dport 42000 accept
ip daddr 192.168.1.20 udp dport 42000 accept
ip daddr 192.168.100.0/24 accept
ip daddr 192.168.220.0/24 accept
ip daddr { 10.139.1.1-10.139.1.2 } tcp dport 53 accept
ip daddr { 10.139.1.1-10.139.1.2 } udp dport 53 accept
ip protocol icmp accept
reject with icmp type admin-prohibited
