Hello. What is a terminal command to open an app in a specified workspace.
For example, open a Chrome browser in Workspace 2.
Also, could you send me a link to the documentation for this topic.
Thank you.
Hello. The desktop environment that qubes ships with by default is XFCE. Since it’s not qubes-specific, I don’t think you’ll find official Qubes documentation on this. But if you look for XFCE Auto starting applications into specific workspaces, you’ll likely find what you’re looking for.
I believe that the standard advice for Xfce is to install devilispie,
which allows you to make applications start in specified workplaces:
you can also set size and placement.
If you install KDE, this has the same functionality built in, and allows
you to set rules using GUI tool.
Some qubes-specific devilspie2 code examples here:
An alternative too is i3. You can use regex to match VM on workspaces
