my Qubes just started booting weird after i tried updating fedora32 template. It was running fine since June 2020. I am running a NitroPad x230 from NitroKey.
Unfortunately, this is not enough. More detailed error description should be in the logs, which you can access from Qube Manager (right click on the qube → Logs) and, for dom0, in its terminal after running journalctl -r (ideally, just after booting).
Maybe someone else can suggest more places to check.
These logs have dates “May 22” as you may see in the beginning of each line. You forgot “-r” after “journalctl” to show the latest lines first.
Let’s start with a description of what that means:
did you attempt to do an in-place upgrade?
did you download the new templates and switch your qubes to it?
If it was 1) and that process failed, this basically leaves you without a functioning template which would explain no qube starting and consequently also no network.
Did you make a clone of the template before starting the upgrade?
Just tell us step by step what you did – that’ll be much faster then trying to guess.
I had similar problems trying to upgrade templates from 4.04 to 4.1b. The fedora template got corrupted and nothing attached to it could start. I restored a debian template from backup and got qubes to start again.
