How can I get 5Ghz WIFI working on QubesOS?
At the moment I only get speed up to 150MBits, so I think my wifi adapte rin dom0 only sees my 2.4Ghz network.
Check your connection settings, maybe it defaults to 2.4 Ghz for some reason. Can you connect to other 5 Ghz networks? Are you sure that your adapter supports 5 Ghz?
