My problem: I need to use obfs3 proxy with my VPN.
I’ve searched and tried a lot of workarounds but I am afraid that in such process of trial and error I might break the VM lock-down state. How can I make it work with qubes-vpn-support?
Well, I cannot help you with this specific problem but since “[…] Obfs3 is not supported anymore.” You can look for “non-standard” VPN / Tor alternatives like:
Thanks, but in my country, for now obfs3 is the only way to get out through openvpn. I managed to get it working on Qubes 3.2 with this VPN setup (Set up a ProxyVM as a VPN gateway using iptables and CLI scripts): https://www.qubes-os.org/doc/vpn/
But I’d prefer to stick with @tasket VPN setup, I really love it.
Right now, I just moved to Qubes R4.0.3 and trying to improve my setup.
Perhaps, answers in here will serve other people from vpn filtered countries.
