There are new updates for my debian-12-xfce with nvidia repositories added and nvidia drivers
I can’t get it to update. Nvidia is either rejecting the IP address or something just isn’t working
I have tried to open up the template and just do a sudo apt update && sudo apt upgrade -y which is probably stupid and it says it can’t make the connection
what’s the right way of handling this? i am using a VPN that probably has a blacklisted IP and normally update through whonix which probably has blacklisted IPs
and I going to have to purchase an IP with a low fraud score just to update my template and maintain my anonymity from nvidia who certainly logs? that seems like a waste of money. or is this a configuration problem? I don’t even know what’s going on.
Can you post the output of this command?
Hit:1 Index of /debian bookworm InRelease
Hit:3 https://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 Index of /compute/cuda/repos/debian12/x86_64 InRelease
Hit:5 Index of /r4.2/vm/ bookworm InRelease
Hit:2 https://deb.librewolf.net bookworm InRelease
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
207 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
libnvidia-rtcore python3-daemon python3-lockfile
Use ‘sudo apt autoremove’ to remove them.
The following NEW packages will be installed:
diffstat ed linux-headers-6.1.0-22-amd64 linux-headers-6.1.0-22-common
linux-image-6.1.0-22-amd64 quilt
The following packages have been kept back:
firmware-nvidia-gsp libcuda1 libcuda1:i386 libegl-nvidia0
libegl-nvidia0:i386 libgl1-nvidia-glvnd-glx libgl1-nvidia-glvnd-glx:i386
libgles-nvidia1 libgles-nvidia1:i386 libgles-nvidia2 libgles-nvidia2:i386
libglx-nvidia0 libglx-nvidia0:i386 libnvcuvid1 libnvcuvid1:i386
libnvidia-allocator1 libnvidia-allocator1:i386 libnvidia-cfg1
libnvidia-eglcore libnvidia-eglcore:i386 libnvidia-encode1
libnvidia-encode1:i386 libnvidia-glcore libnvidia-glcore:i386
libnvidia-glvkspirv libnvidia-glvkspirv:i386 libnvidia-ml1 libnvidia-nvvm4
libnvidia-ptxjitcompiler1 libnvidia-ptxjitcompiler1:i386 nvidia-alternative
nvidia-driver nvidia-driver-bin nvidia-driver-libs nvidia-driver-libs:i386
nvidia-egl-icd nvidia-egl-icd:i386 nvidia-kernel-open-dkms
nvidia-kernel-support nvidia-open-kernel-source nvidia-open-kernel-support
nvidia-opencl-icd nvidia-smi nvidia-tesla-alternative nvidia-vdpau-driver
nvidia-vulkan-icd nvidia-vulkan-icd:i386 xserver-xorg-video-nvidia
The following packages will be upgraded:
base-files bash curl distro-info-data dns-root-data
firmware-nvidia-tesla-gsp fonts-opensymbol gir1.2-gdkpixbuf-2.0
gir1.2-gst-plugins-base-1.0 gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0
gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-plugins-base gstreamer1.0-x
intel-microcode krb5-locales libarchive13 libavcodec59 libavfilter8
libavformat59 libavutil57 libbluetooth3 libcjson1 libcurl3-gnutls libcurl4
libfreetype6 libgdk-pixbuf-2.0-0 libgdk-pixbuf2.0-bin
libgdk-pixbuf2.0-common libglib2.0-0 libglib2.0-bin libglib2.0-data
libgnutls30 libgssapi-krb5-2 libgstreamer-gl1.0-0
libgstreamer-plugins-base1.0-0 libjavascriptcoregtk-4.0-18
libjavascriptcoregtk-4.1-0 libk5crypto3 libkrb5-3 libkrb5support0
libltdl-dev libltdl7 libndp0 libnvidia-gpucomp1 libnvidia-gpucomp1:i386
libnvidia-rtcore libpam-systemd libpostproc56 libpython3.11
libpython3.11-minimal libpython3.11-stdlib libqrexec-utils2
libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5
libqt5widgets5 libqubes-pure0 libqubes-rpc-filecopy2 libqubesdb
libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core
libreoffice-draw libreoffice-gtk3 libreoffice-help-common
libreoffice-help-en-us libreoffice-impress libreoffice-math
libreoffice-style-colibre libreoffice-writer librewolf libseccomp2 libssl3
libswresample4 libswscale6 libsystemd-shared libsystemd0 libtool libudev1
libuno-cppu3 libuno-cppuhelpergcc3-3 libuno-purpenvhelpergcc3-3 libuno-sal3
libuno-salhelpergcc3-3 libvpx7 libwebkit2gtk-4.0-37 libwebkit2gtk-4.1-0
libxnvctrl0 linux-compiler-gcc-12-x86 linux-headers-amd64 linux-image-amd64
linux-kbuild-6.1 linux-libc-dev nano nvidia-cuda-mps nvidia-egl-common
nvidia-kernel-source nvidia-legacy-check nvidia-libopencl1 nvidia-modprobe
nvidia-opencl-common nvidia-persistenced nvidia-settings
nvidia-tesla-legacy-check nvidia-vulkan-common openssh-client openssl
pipewire-qubes python3-idna python3-pil python3-qrexec python3-qubesdb
python3-qubesimgconverter python3-software-properties python3-uno python3.11
python3.11-minimal qemu-block-extra qemu-system-data qemu-system-xen
qemu-utils qt5-gtk-platformtheme qubes-core-agent
qubes-core-agent-dom0-updates qubes-core-agent-nautilus
qubes-core-agent-network-manager qubes-core-agent-networking
qubes-core-agent-passwordless-root qubes-core-agent-thunar qubes-core-qrexec
qubes-gui-agent qubes-gui-agent-xfce qubes-kernel-vm-support qubes-usb-proxy
qubes-utils qubes-vm-dependencies qubes-vm-recommended qubesdb qubesdb-vm
software-properties-common software-properties-gtk systemd systemd-sysv
systemd-timesyncd thunderbird tinyproxy tinyproxy-bin udev uno-libs-private
ure wpasupplicant xserver-xorg-input-qubes xserver-xorg-qubes-common
xserver-xorg-video-dummyqbs
159 upgraded, 6 newly installed, 0 to remove and 48 not upgraded.
Need to get 41.8 MB/563 MB of archives.
After this operation, 463 MB of additional disk space will be used.
Err:1 Index of /compute/cuda/repos/debian12/x86_64 nvidia-kernel-source 555.42.06-1
403 Forbidden [IP: 127.0.0.1 8082]
E: Failed to fetch https://developer.download.nvidia.com/compute/cuda/repos/debian12/x86_64/./nvidia-kernel-source_555.42.06-1_amd64.deb 403 Forbidden [IP: 127.0.0.1 8082]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Are you updating using Tor?
I guess nvidia is blocking Tor usage.
