Latest akmod-nvidia update has dependencies conflicting with qubes:
Last metadata expiration check: 1:15:29 ago on Wed Jul 31 08:58:41 2024.
Dependencies resolved.
Problem 1: package xorg-x11-drv-nvidia-3:555.58.02-1.fc39.x86_64 from rpmfusion-nonfree-updates requires /usr/sbin/grubby, but none of the providers can be installed
- installed package grubby-dummy-9.0.0-4.fc39.noarch obsoletes grubby < 9.0.0 provided by grubby-8.40-72.fc39.x86_64 from fedora
- installed package grubby-dummy-9.0.0-4.fc39.noarch obsoletes grubby < 9.0.0 provided by grubby-8.40-73.fc39.x86_64 from updates
- package sdubby-1.0-7.fc39.noarch from updates conflicts with grubby provided by grubby-dummy-9.0.0-4.fc39.noarch from @System
- package grub2-common-1:2.06-121.fc39.noarch from @System conflicts with grubby < 8.40-18 provided by sdubby-1.0-4.fc39.noarch from fedora
- cannot install the best update candidate for package xorg-x11-drv-nvidia-3:550.90.07-1.fc39.x86_64
- cannot install the best update candidate for package grubby-dummy-9.0.0-4.fc39.noarch
- cannot install the best update candidate for package grub2-common-1:2.06-121.fc39.noarch
Problem 2: problem with installed package grubby-dummy-9.0.0-4.fc39.noarch
- package sdubby-1.0-4.fc39.noarch from fedora conflicts with grubby provided by grubby-dummy-9.0.0-4.fc39.noarch from @System
- package sdubby-1.0-4.fc39.noarch from fedora conflicts with grubby provided by grubby-dummy-9.0.0-4.fc39.noarch from qubes-vm-r4.2-current
- package xorg-x11-drv-nvidia-3:555.58.02-1.fc39.x86_64 from rpmfusion-nonfree-updates requires /usr/sbin/grubby, but none of the providers can be installed
- package grubby-dummy-9.0.0-4.fc39.noarch from qubes-vm-r4.2-current obsoletes grubby < 9.0.0 provided by grubby-8.40-72.fc39.x86_64 from fedora
- package grubby-dummy-9.0.0-4.fc39.noarch from qubes-vm-r4.2-current obsoletes grubby < 9.0.0 provided by grubby-8.40-73.fc39.x86_64 from updates
- package sdubby-1.0-7.fc39.noarch from updates conflicts with grubby provided by grubby-dummy-9.0.0-4.fc39.noarch from qubes-vm-r4.2-current
- package akmod-nvidia-3:555.58.02-1.fc39.x86_64 from rpmfusion-nonfree-updates requires nvidia-kmod-common >= 3:555.58.02, but none of the providers can be installed
- cannot install the best update candidate for package akmod-nvidia-3:550.90.07-1.fc39.x86_64
Package Architecture Version Repository Size
Skipping packages with conflicts:
(add '--best --allowerasing' to command line to force their upgrade):
sdubby noarch 1.0-4.fc39 fedora 18 k
sdubby noarch 1.0-7.fc39 updates 18 k
Skipping packages with broken dependencies:
akmod-nvidia x86_64 3:555.58.02-1.fc39 rpmfusion-nonfree-updates 40 k
xorg-x11-drv-nvidia x86_64 3:555.58.02-1.fc39 rpmfusion-nonfree-updates 126 M
Transaction Summary
Skip 4 Packages
Nothing to do.
Complete!
What can be done?
p.s. nouveau is great, but doesn’t support all features (yet).
