I click the checkbox for numbers lock for the 105 key keyboard so that it is turned on when I boot. It does not seem to work for me.
Are you using KDE? If so, head into the system settings then to Input Devices, and, at last, the Keyboard section has a NumLock On PS. Turn that on and apply.
Hi HPOA909
I am using xFce desktop environment and I have checkmarked the keyboard setting " Restore num lock on startup" . Even after doing this I have to manual set the num lock after I boot my system.
Did you automatically attach most of your keyboard and mouse to the DOM0?
@adw move this topic
My situation is that I am using a usb keyboard/mouse interface with my computer. My Cube computer is a standalone that has no other OS on its drives. I do use a device that allows me to share the keyboard /mouse with my separate Windows computer. As far as automatically attaching itself to DOM0 the only thing I could add about the question is I have not changed the default installtion setup related to how the keyboard/mouse is attached to DOM0. The only thing I have changed is the check box that I previously noted in my earlier posts. Hope this explains a little more of my situation related to my issue.
@deeplow change this shitty topic tag from Feedback to user support 4.1
Moved this topic into ‘User Support’.
moderator's note
@HPOA909 maybe you are not a native speaker: your requests to @adw and @deeplow could be considered rude as they sound like orders. Also we don’t like calling out specific members of the moderation team here. The best way is to flag a post for attention and leave a short message requesting the moving into another category. This way you don’t spam the thread and the next available moderator will see it.
alright
Someone in this section will help you solve that problem.
Thanks
