Tried the latest ISO:
Qubes-20210424-x86_64.iso
24-Apr-2021 04:53
5408555008
and the previous ISO:
Qubes-20210417-x86_64.iso
17-Apr-2021 06:49
5408555008
In the installer every few minutes the python3 storage job
python3 -m pyanaconda.modules.storage
runs out of memory. In top on tty2 (shell) I see it running at 95+ % CPU usage and increasing memory percentage until it crashes and restarts.
I have 16 GB installed and it uses almost 4 GB for the installer.
From dmesg:
[ 975.060113] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/anaconda.service,task=python3,pid=5829,uid=0 [ 975.060146] Out of memory: Killed process 5829 (python3) total-vm:3374476kB, anon-rss:3100836kB, file-rss:5960kB, shmem-rss:0kB, UID:0 pgtables:6248kB oom_score_adj:0 [ 976.409429] audit: type=1131 audit(1619353452.886:505): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=anaconda-tmux@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed' [ 976.416786] audit: type=1130 audit(1619353452.893:506): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=anaconda-tmux@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' [ 976.416822] audit: type=1131 audit(1619353452.894:507): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=anaconda-tmux@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' [ 976.599788] oom_reaper: reaped process 5829 (python3), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
checking for other details (syslog, storage log, . . .)
It logs that it found 56 devices and then it fails after processing md8. It never logs md9, the last item in the list.
Some raid devices are inactive. Then it waits longer before it processes the next.
Hans
